Virgin of 7G-tronic VGS2 units by Vediamo - Printable Version
+---- Thread: Virgin of 7G-tronic VGS2 units by Vediamo (/Thread-Virgin-of-7G-tronic-VGS2-units-by-Vediamo)
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20
Virgin of 7G-tronic VGS2 units by Vediamo - gearbox.expert - 05-24-2020
Hi Mates!
Referring to my earlier posts I would like to announce, that I can finally publish my files to virginize VGS2 units. It took a long time before a sufficiently large group of interested people finally gathered. I hope that such idle waiting did not last too long for you. Wink
So, I have prepared and attached modified CBF file with according script file to make it all easy to use even for unexperienced users. It works on bench and OBD2 connector. Tested with Vediamo 04.02.02 and C3 chinese MUX, as well as Vediamo 05.00.05 and chinese SD-Connect. It was not tested yet on any pass-thru devices - feedback highly appreciated!
To play with it, just copy unpacked VGSmod2.cbf into directory, in which you keep all your cbf. files. Than open Vediamo, choose the VGSmod2.cbf and load it. In this moment a new subdirectory named "VGSmod2" should be created in ..\VediamoData. Copy unpacked VGS2-Virgin.xml script into this subdirectory.  Now preparation is finished. To erase personalisation keys from 7G-Tronic VGS2 just establish connection to TCU, go to Sequences, press Execute Sequence (not OPEN, just EXECUTE!) Nod , choose and start VGS2-Virgin.xml and follow the steps.
Here you can see tutorial how to use it: https://youtu.be/62L3kQAPcOA
Remember - this solution works ONLY on TCU's with part number A 033 545 73 32! Once TCU is virgin (some areas of EEPROM memory are erased) it must be prepared to be used in next car. Depending of software version and EEPROM memory layout, virginising can (but not always have to) erase also VIN, CALID, Shift lever learning values or SCN. All this need to be performed after reusing TCU on different car. THERE IS NO NEED TO PESONALIZE AND ACTIVATE your TCU to make it work. This 722.9 VGS units will work well even without performing that steps. All VGS (Gen 1,2,3) using FBS3 immobiliser system will activate and personalize automatically after 300 ignition cycles. No additional actions are needed. To use your virginized TCU on any Mercedes 722.9 Gearbox, you need to be sure than actual software version fit this car (VIN) with this valve body (EHS number) and Coding is equal to destination car equippment. If software version is not right, some codings can be refused. It is always recommended to reflash the unit after virginizing to restore its EEPROM layout and perform software update. Support on this can be found in other MHH topics.
Of course I am not responsible for any damages or problems that you will cause using this script without proper knowledge and technical awareness. If you have any doubts, simply don't use it! Each problem you will have is the result of your technical ignorance or lack of attention. Don't expect help if you can't even describe exactly what you did. If you are not protocoling each stage, it will significantly hinder finding the cause, especially when performing multi-stage changes, as in the case of TCU replacement...
No password needed. Enjoy!
Have a good day,
GEARBOX.EXPERT
RE: Virgin of 7G-tronic VGS2 units by Vediamo - part three. - kada2015 - 05-27-2020
hi gearbox.expert
first of all thanks for your scharing.
and it's really a good tutorial you shared between us and it will help a lot of the memes who have not avdi / fvdi.
I hope that one day you will find a solution to virgin vgs 3
thanks and i di d thanks and reputation for you
RE: Virgin of 7G-tronic VGS2 units by Vediamo - part three. - gearbox.expert - 05-27-2020
Who is deleting posts from this thread!?
Unbelievable!  39
RE: Virgin of 7G-tronic VGS2 units by Vediamo - part three. - gcs190 - 05-27-2020
Normal that they eliminate you post, you are a parasite looking to sell their product and your solution is archaic and incomplete and you continue to make clients and select who you send it to according to your interests.Whoever wants the partial solution of this element send me an MP and I will send it to them.
Here I leave you the solution of the commercial "Gearbox_Expert" so that you do not have to sell your soul to the devil in exchange for promises that it will not keep:
[attachment=355025]
The next time maybe you think better of who to cheat, I do not give my email to a parasite like you if I know you are a parasite.
By the way, your solution is a real shit, if you had really investigated, you would know that it is much easier ... I doubt that only this solution is yours. I wish you the best sales, but that they are of quality, because your fame precedes you and it is not exactly good ...
RE: Virgin of 7G-tronic VGS2 units by Vediamo - part three. - gearbox.expert - 05-28-2020
Some people are really strange...  533
The file VGSmod2.zip  should be used in combination with VGS2-Virgin.zip ,so giving only one file will not help anyone, nor proof anything...
Who is a parasite and cheater???
If you have better and easier FREE solution, why did you not posted it yet?
RE: Virgin of 7G-tronic VGS2 units by Vediamo - part three. - W214 - 05-28-2020
(05-27-2020, 11:13 PM)gcs190 Wrote: Here I leave you the solution of the commercial "Gearbox_Expert" so that you do not have to sell your soul to the devil in exchange for promises that it will not keep:
I agree with you!
RE: Virgin of 7G-tronic VGS2 units by Vediamo - part three. - sixcode - 05-28-2020
(05-27-2020, 07:12 PM)gearbox.expert Wrote: Who is deleting posts from this thread!?
Unbelievable!  39
 i am, post like good job and pass please are no posts we have a thanks button for that...
Understand... Post like "good job" are not welcome. Post like "shit and cheat" will stay. I still have a feeling, that few people still do not want me to publish this solution... Itwasntme
