xdiag pro3 G1002 question about - Printable Version
+--- Forum: Mobile Automotive Android/IOS/Windows CE (https://mhhauto.com/Forum-Mobile-Automotive-Android-IOS-Windows-CE)
+--- Thread: xdiag pro3 G1002 question about (/Thread-xdiag-pro3-G1002-question-about)
xdiag pro3 G1002 question about - Makrem88 - 07-18-2020
Hello i have this Xdiag pro3 2019 i think the russian one with online serveur i use app Xdiag PRO3 V3.12.038
It's working great in diagonsis and all but for the new update of reset adblue rest airbag and others i don't found also for coding online i get all the time error
Is there any update for the apk or change or what
Can someone help me
I attach the pics of the soft and hard
RE: xdiag pro3 G1002 question about - mgrka - 07-19-2020
you device is golo carcare, it's not the software's fault, but that you have the worst possible device ,The sellers' quarrel is about to begin ...
Peel this sticker off the head and everything will be explained
RE: xdiag pro3 G1002 question about - Makrem88 - 07-20-2020
Ok my friend thank you for the response
and what the best here there is thnkdiag with digizone is't ok
or tell me the best
RE: xdiag pro3 G1002 question about - plesko - 07-20-2020
Hello friend
If you have Xdiag activation all the resets should work. And what mgrka said its not true i have myself xdiag activation on golo carcare and it works great. It work even better than original 3.0 on DZ activation, i have tested all connectors and i can tell you that Golo Carcare in my opinion is a good connector and for me everything is working as it should.
As for your problem, first update android on your tablet/phone, then go to update and update Xdiag app if all this fails go and check which anroid do you have it must not be "Oreo" because the app has a problem with this kind of android! If all else fails then it could be some other error so just delete the Xdiag app, go to folder and manually delete Xdiag folder and reinstall and dont worry all will work Wink
If i helped please rep +1 and have a great day
RE: xdiag pro3 G1002 question about - warezhr - 07-21-2020
(07-19-2020, 10:15 PM)mgrka Wrote: you device is golo carcare, it's not the software's fault, but that you have the worst possible device ,The sellers' quarrel is about to begin ...
Peel this sticker off? So what if there is sticker, it had to be flashed by st-link to be able work with xdiag. Your answer has nothing to do with his question.
