Star DAS No communication to several ESM/ESP/Suspension modules - Printable Version +- MHH AUTO (https://mhhauto.com) +-- Forum: MHH AUTO FORUMS. (https://mhhauto.com/Forum-MHH-AUTO-FORUMS) +--- Forum: Automotive Software. (https://mhhauto.com/Forum-Automotive-Software) +--- Thread: Star DAS No communication to several ESM/ESP/Suspension modules (/Thread-Star-DAS-No-communication-to-several-ESM-ESP-Suspension-modules) |
Star DAS No communication to several ESM/ESP/Suspension modules - PhatAgent - 08-12-2020 Hey guys, As it says, I cannot communicate to any of those control modules on a C215 CL55. This is my second CL55 that DAS will not communicate to those modules so that rules out it being a car isolated issue like canbus communication down. I just recently got the car and have been going through little things it needs, I want to replace some ABC parts later so I can do the rodeo but I cannot get into the Suspension ABC module. For example, If i try to communicate to ESM a popup "VCI Firmware update GPD KWFB is being loaded" and then it will say no communication to module can be established. Perhaps it is a software issue.. If so, what could I be missing? Install Setup is a Late 2018 version I believe. I also cannot communicate to two 211 SBC modules either. Any ideas? RE: Star DAS No communication to several ESM/ESP/Suspension modules - lashe - 08-24-2020 what version you using, and wat model of tool c4 or c3 RE: Star DAS No communication to several ESM/ESP/Suspension modules - PhatAgent - 12-23-2020 (08-24-2020, 08:43 AM)lashe Wrote: what version you using, and wat model of tool I know this is late, but the tool is a C4 clone. Software is dated is like 2018/03 if I recall correctly. It may be software related, I'm not too sure. The C4 tool works with my other benzes and I do hear several clicks from the mux when attempting to connect to the modules. RE: Star DAS No communication to several ESM/ESP/Suspension modules - mutec99 - 12-27-2020 For the start, do selfe test and attach the results. |
