Simos 11.1 pinout - Printable Version
+--- Thread: Simos 11.1 pinout (/Thread-Simos-11-1-pinout)
Simos 11.1 pinout - m5000 - 10-15-2020
Hi,
Does anyone knows how to connect KTM-BENCH ECU Programmer to Simos 11.1 CPU?
RE: Simos 11.1 pinout - m5000 - 10-18-2020
Really, nobody knows it?
RE: Simos 11.1 pinout - eltiobarbas - 10-19-2020
(10-18-2020, 03:25 PM)m5000 Wrote: Really, nobody knows it?
Simos 11.1 Pinout
PIN 20 -> CAN H
PIN 21 -> CAN L
PIN 1,2 -> -GND
PIN62 -> +15A
PIN73 -> +30A
[18:59:28] Reading ID ...
[18:59:28] VIN: WVWZZZ6RZCYXXXXXX
[18:59:28] FAZIT Serial:
[18:59:28] Part Number: 03E906019M
[18:59:28] Software: 8949
[18:59:28] ASAM: EV_ECM12MPI02103E906019M
[18:59:28] ASAM Version: 001007
[18:59:28] Hardware: 03E906019B
[18:59:28] System Name: SIMOS11.1
[18:59:28] Engine Code: CGPB
[18:59:28] FAZIT: SJ8-FST04.06.1100080311
[18:59:28] Coding: 00110016000400080000
[18:59:29] WSC: 00255 - 648 - 00788
[18:59:29] Brand: VW
[18:59:29] Programming Attempts: 0-0-0
[18:59:29] Successful Attempts: 0-0-0
[18:59:29] ############# Blocks Info #############
[18:59:29] Block 1: Date: FF-FF-FF WSC: 00000 - 000 - 00000 Status: Correct result
[18:59:29] Block 2: Date: 00-00-00 WSC: 00000 - 000 - 00000 Status: Correct result
[18:59:29] Block 3: Date: 00-00-00 WSC: 00000 - 000 - 00000 Status: Correct result
[18:59:29] ###################################
[Image: Screenshot-62.png]
RE: Simos 11.1 pinout - m5000 - 11-26-2020
Thanks. The problem was with programmer.
RE: Simos 11.1 pinout - Owdi - 12-14-2020
@Eltiobarbas, do you have the pinout for Simos 10.24?
Also do you have a more full pinout for 11.1, does it also have a K-line pin on the ECU?
