A class (start error) - Printable Version +- MHH AUTO (https://mhhauto.com) +-- Forum: MHH AUTO FORUMS. (https://mhhauto.com/Forum-MHH-AUTO-FORUMS) +--- Forum: General Automotive Help & Discussions. (https://mhhauto.com/Forum-General-Automotive-Help-Discussions) +---- Forum: Daimler Group Mercedes-Benz, Smart Discussions. (https://mhhauto.com/Forum-Daimler-Group-Mercedes-Benz-Smart-Discussions) +---- Thread: A class (start error) (/Thread-A-class-start-error) |
A class (start error) - techman1 - 01-19-2011 Hi guys, have a year 2000 diesel mercedes aclass which has developed a start error message on the instrument panel. Fault has only been present since battery change, have used star diagnostics and only fault is B1000 ( replace control module)stored in the siemens 5wk4 736 immo module. can this be cleared at component level? thanks in advance for any information. RE: A class (start error) - energjia - 01-19-2011 (01-19-2011, 12:19 AM)techman1 Wrote: Hi guys, have a year 2000 diesel mercedes aclass which has developed a start error message on the instrument panel. Fault has only been present since battery change, have used star diagnostics and only fault is B1000 ( replace control module)stored in the siemens 5wk4 736 immo module. can this be cleared at component level? thanks in advance for any information. you can do it by star diagnostics , coding RE: A class (start error) - techman1 - 01-19-2011 (01-19-2011, 01:26 AM)energjia Wrote:(01-19-2011, 12:19 AM)techman1 Wrote: Hi guys, have a year 2000 diesel mercedes aclass which has developed a start error message on the instrument panel. Fault has only been present since battery change, have used star diagnostics and only fault is B1000 ( replace control module)stored in the siemens 5wk4 736 immo module. can this be cleared at component level? thanks in advance for any information. hi, thanks for reply. How can you do it with star? RE: A class (start error) - webmaster - 01-19-2011 Actually I'd never get any A class in my work shop so I dont have Any idea. But for example in w211 we go to Battery Control Module "BCM" and we erase the fault. Check if u have BCM in A Class
RE: A class (start error) - zoka6767 - 01-20-2011 I had same problem with one A-class . The module had lost its coding , and I had to take ecu and imo ,and I went to an electrician to program them . Sorry for my bad English , I hope my expirience would help ![]() Regards RE: A class (start error) - energjia - 01-20-2011 (01-20-2011, 05:38 PM)zoka6767 Wrote: I had same problem with one A-class . sory for not explained well! go to the CDI module and will pop up the HHTWIN and than go to 5 Controlle module adaption than 4 Identification if you need more help contact me i will help with teamviwer. all the best RE: A class (start error) - techman1 - 01-22-2011 (01-20-2011, 09:08 PM)energjia Wrote:(01-20-2011, 05:38 PM)zoka6767 Wrote: I had same problem with one A-class . sorry for delay in responding, been away from work ill. Thanks for all your input, i will go back to car on monday. so by going to HHTWIN then control module adaption, followed by identification your able to re sync with immo? RE: A class (start error) - energjia - 01-22-2011 (01-22-2011, 03:12 AM)techman1 Wrote:(01-20-2011, 09:08 PM)energjia Wrote:(01-20-2011, 05:38 PM)zoka6767 Wrote: I had same problem with one A-class . yes RE: A class (start error) - techman1 - 01-22-2011 (01-22-2011, 03:20 AM)energjia Wrote:(01-22-2011, 03:12 AM)techman1 Wrote:(01-20-2011, 09:08 PM)energjia Wrote:(01-20-2011, 05:38 PM)zoka6767 Wrote: I had same problem with one A-class . i will give it a try and let you know, many thanks
