Issues with KSUITE. - Printable Version
+--- Thread: Issues with KSUITE. (/Thread-Issues-with-KSUITE)
Issues with KSUITE. - FezMonki - 03-29-2021
Hello everyone, apologies if it's the wrong section but I couldn't find one for outright questions.
I'm having two problems with my KESS/KSUITE (I'm using the MHH Branded KSUITE I got off the forum):
1. Every time I open KSUITE with the KESS connected via USB it takes FOR EVER and claims it's updating it every time, it goes through like 600 files and takes 15 minutes.
2. I was trying to read the ECU of an Opel Astra 2000, and kept getting Checksum Error at the end of reading, and the file would be 256kb:
[Image: oXZtVUf.png]
To be fair the computer and car weren't connected to power, could that be it?
I read the ECU off my Mom's Volvo S60 without any issue however.
This is my first time doing anything with ECUs, thank you for your help.
FezMonki.
RE: Issues with KSUITE. - MSolen - 03-30-2021
1- in folder Ksuite ->Update delete all file and the update will stop
RE: Issues with KSUITE. - FezMonki - 03-30-2021
Perfect thank you! It was driving me nuts. I'll get back to the Opel Astra this afternoon and come back to poke if it persists.
Ok, nevermind point 2. I had reinstalled the computer and didn't have c++ runtimes, installed those and the checksum error didn't show again.
I removed the EGR with EGR remover and flashed the file back on the car, everything seems to be working fine. I didn't correct the checksums with winols, did ksuite correct them? Can I keep on just ksuite -> dpf/egr remover -> ksuite write also on newer cars and it shouldn't give issues? Thanks.
RE: Issues with KSUITE. - cosworth89 - 07-31-2024
Any idea why ksuite keeps deleting the program everytime it's run? I have to keep unpacking it back into the destination folder lol
RE: Issues with KSUITE. - GdcD - 08-12-2024
Hello forum activists!
I need some background/expertise regarding ECU selection at KTAG.
I couldn't find a VW TOUAREG (7L) V10 5.0 TDi (BLE) M&S.
I then took another VW model,
whose ECU and thus also MPC + FLASH + EEPROM are/were identical.
There were of course extreme differences to this vehicle:
VW TRANSPORTER T5 (7H) 1.9 TDi (BRS)
Reprogramming went without any problems!
The vehicle runs WITHOUT any noticeable errors.
Now the question:
Can there be problems,
since the V10 is a master-slave system?
There is a cable connection between J623 and J624.
Is this how the communication exchange is regulated?
So, both ECU's kept their ORIGINAL MPC and also the ORIGINAL EEPROM.
ONLY the FLASH was modified.
And of course: All errors are gone in the cockpit display.
I would like to thank everyone for your well-founded feedback!
Best regards, GdcD
