Update SIMOS 18.1 5G0906259 to 5G0906259C - Printable Version +- MHH AUTO (https://mhhauto.com) +-- Forum: MHH AUTO FORUMS. (https://mhhauto.com/Forum-MHH-AUTO-FORUMS) +--- Forum: Automotive Tuning. (https://mhhauto.com/Forum-Automotive-Tuning) +--- Thread: Update SIMOS 18.1 5G0906259 to 5G0906259C (/Thread-Update-SIMOS-18-1-5G0906259-to-5G0906259C) |
Update SIMOS 18.1 5G0906259 to 5G0906259C - tatsumaki - 05-14-2021 Good companions. I would like to know if someone was able to update an ecu simos 18.1 ref 5G0906259 to a 5G0906259C with odis. loading the .frf. The ref of hw is the same in both. But I don't know if it would be necessary to parameterize in odis .... thank you !!! RE: Update SIMOS 18.1 5G0906259 to 5G0906259C - tatsumaki - 05-15-2021 no one?? RE: Update SIMOS 18.1 5G0906259 to 5G0906259C - TIGRI007 - 05-15-2021 (05-15-2021, 11:43 AM)tatsumaki Wrote: no one?? contact me below to explain better. RE: Update SIMOS 18.1 5G0906259 to 5G0906259C - asso81 - 06-14-2021 hi are you successful? RE: Update SIMOS 18.1 5G0906259 to 5G0906259C - jnoroeste - 06-14-2021 Hi M8, why you need update?? Have changed any sensor/part??Regards. RE: Update SIMOS 18.1 5G0906259 to 5G0906259C - TIGRI007 - 06-14-2021 (06-14-2021, 01:27 PM)asso81 Wrote: hi are you successful? Yes flash went good. Just make a backup of old coding to be sure any inconvenience. RE: Update SIMOS 18.1 5G0906259 to 5G0906259C - parik - 06-15-2021 yes there is working. posible to crossflash dsg for farting. RE: Update SIMOS 18.1 5G0906259 to 5G0906259C - en3rgy - 09-18-2021 (05-14-2021, 03:08 AM)tatsumaki Wrote: Good companions. I would like to know if someone was able to update an ecu simos 18.1 ref 5G0906259 to a 5G0906259C with odis. loading the .frf. The ref of hw is the same in both. But I don't know if it would be necessary to parameterize in odis .... thank you !!! Hi, i was trying it but its also required to update DSG(because my appears to be an old revision) and tried a lot of DSG SW versions. ECU was succesfull comunicating with the TCU but i had problems with gear changes in higher gears and RPM (DSG stopped working during drive, needed to restart engine). I think there is a special modified version needed for my TCU to work with the C index. My TCU: Part No SW: 0D9 300 020 B HW: 02E 927 770 AN Component: DQ250-6F MQB H52 4008 Revision: 05652104 Drivers Door control unit had no connection to the ECU, but all worked.(Maybe it can be replaced with a newer one, because Update with ODIS/VCP dont worked). RE: Update SIMOS 18.1 5G0906259 to 5G0906259C - DenPhi - 09-19-2021 (06-15-2021, 02:26 AM)parik Wrote: yes there is working. posible to crossflash dsg for farting. How to find matching sw for ecu and dsg? Can someone explain? |
