DELPHI DCM6.2v immo off - Printable Version
+--- Thread: DELPHI DCM6.2v immo off (/Thread-DELPHI-DCM6-2v-immo-off)
DELPHI DCM6.2v immo off - kukata_83 - 08-09-2021
Hello,
can anyone help with this computer immo off
car is VW POLO 1,4 TDIĀ  2014
ECU: DELPHI DCM 6.2V
04B907445
The car cannot start
nozzles, pump checked (no nozzle control)
No error in ECU
The car had an accident without airbags open.
RE: DELPHI DCM6.2v immo off - Drakonas1 - 08-09-2021
Check crash sensor
RE: DELPHI DCM6.2v immo off - kukata_83 - 08-09-2021
Car dont open airbag.
no errors in SRS unit, dont see mehanic crash sensor
RE: DELPHI DCM6.2v immo off - Phoenix13 - 08-10-2021
Hello, does the ecu see the rotation of the shaft and camshaft,
I know that you checked the pump, but what pressure on the rail during start-up.
Fuses carefully checked? Cables nowhere crushed?
RE: DELPHI DCM6.2v immo off - kukata_83 - 08-10-2021
Pressure 200-400 bar
Crankshaft end camshaft rotated.
Injectors tested (in company for test end recycling)
RE: DELPHI DCM6.2v immo off - dmajooo - 09-07-2021
Hey guys
I Have some problem with Fabia 3 ..... engine wont start, NO ERRORS
fuel pressure ok
fuel regulator ok
speed sensors ok
injectors tested ok
fuel pump ok
Did you solve this problem ??
Thanks Smile
RE: DELPHI DCM6.2v immo off - Stig33 - 09-08-2021
Not possible reading this ecu....
RE: DELPHI DCM6.2v immo off - kukata_83 - 09-17-2021
In my event i don t have synhronisation
between crankshaft and camshaft.
I solved the problem with timing belt replacement
