Smart 451 ECU clone or code - Printable Version +- MHH AUTO (https://mhhauto.com) +-- Forum: MHH AUTO FORUMS. (https://mhhauto.com/Forum-MHH-AUTO-FORUMS) +--- Forum: Automotive Airbag, Dash, ECU, IMMO. (https://mhhauto.com/Forum-Automotive-Airbag-Dash-ECU-IMMO) +--- Thread: Smart 451 ECU clone or code (/Thread-Smart-451-ECU-clone-or-code) |
Smart 451 ECU clone or code - immotoolscy - 11-19-2021 Hi guys anyone knows how to adapt used ECU to smart 451 with diesel engine.ecu is edc16c32. I tried with pcm flash but still key on dash. I code also keys with key programmer still the same. ![]() Sent from my M2101K7AG using Tapatalk RE: Smart 451 ECU clone or code - Antonio266 - 11-19-2021 Second hand ECU must be same HW or compatible.. Then with PCMFlash you have to write both Eeprom and Flash, and when you have to write it, de-flag the 'Skip Service Areas' option. Otherwise you can make clone in BDM with Ktag or something like that, or virgin ECU + pairing with car Smart 451 ECU clone or code - immotoolscy - 11-19-2021 Hw i same and ECU is compatible. I succeed to read flash and external flash.eeprom is all 0000 in both ECus. I will try that scip on Monday. Also I Heard that you can just adapt with das without touching ECU and offline. I couldn't found my ecu in ktag. ![]() Sent from my M2101K7AG using Tapatalk RE: Smart 451 ECU clone or code - immotoolscy - 11-21-2021 (11-19-2021, 10:12 PM)Antonio266 Wrote: Second hand ECU must be same HW or compatible..Thanks Antonio266.it work with unclick service area. Sent from my M2101K7AG using Tapatalk RE: Smart 451 ECU clone or code - bloedman - 05-21-2024 (11-19-2021, 10:38 PM)immotoolscy Wrote: Hw i same and ECU is compatible. Sorry for hijacking this old thread. But I have the same ECU on my bench and KTAG. BDM Port ist on the other side of the ECU. How can I remove the heatsink savely? Thanks RE: Smart 451 ECU clone or code - Ct33dst - 05-22-2024 (05-21-2024, 11:36 PM)bloedman Wrote:Remove the screws and with a heating gun heat on the back side of acu and with a flat screw drive just lift the bord easy from a corner to another i have opened 2 like this for clone 2 weaks ago(11-19-2021, 10:38 PM)immotoolscy Wrote: Hw i same and ECU is compatible. |
