MB W220 EIS &ESM VIN - Printable Version +- MHH AUTO (https://mhhauto.com) +-- Forum: MHH AUTO FORUMS. (https://mhhauto.com/Forum-MHH-AUTO-FORUMS) +--- Forum: Automotive Airbag, Dash, ECU, IMMO. (https://mhhauto.com/Forum-Automotive-Airbag-Dash-ECU-IMMO) +--- Thread: MB W220 EIS &ESM VIN (/Thread-MB-W220-EIS-ESM-VIN) |
MB W220 EIS &ESM VIN - Mobd3 - 12-13-2021 Hi, i have Mercedes benz w220 s500 2003, with dead EIS, after replacing EIS and ESM the car able to unlock and start without issue, but the odometer shows dashes, the VIN number on EZS different than the car chassis , any way to reaolve this issue and change the vin to the car chassis number with DAS? RE: MB W220 EIS &ESM VIN - bersch8688 - 12-13-2021 Repair original EIS RE: MB W220 EIS &ESM VIN - Mobd3 - 12-13-2021 not able to repair, the original one, the Vin was not showing in dashboard, the car most of time not able to unlock and not able to start rather than get communication with DAS RE: MB W220 EIS &ESM VIN - l0x2 - 12-13-2021 Try to read at least SSID & Hashes out of it, you could also try getting the Key HASH out of ESM, by writing ori VIN & SSID to replacement EZS it will aync with cluster, EZS milage muat be lower than IC, if you write key Hashes, ori ESM will work as well RE: MB W220 EIS &ESM VIN - Mobd3 - 12-13-2021 (12-13-2021, 06:52 PM)l0x2 Wrote: Try to read at least SSID & Hashes out of it, you could also try getting the Key HASH out of ESM, by writing ori VIN & SSID to replacement EZS it will aync with cluster, EZS milage muat be lower than IC, if you write key Hashes, ori ESM will work as well read of old EZS module? looks till not able to do if you could guide, old ESM or new esm? further explanation will be appreciated RE: MB W220 EIS &ESM VIN - BrokeGates - 12-13-2021 (12-13-2021, 07:11 PM)Mobd3 Wrote:(12-13-2021, 06:52 PM)l0x2 Wrote: Try to read at least SSID & Hashes out of it, you could also try getting the Key HASH out of ESM, by writing ori VIN & SSID to replacement EZS it will aync with cluster, EZS milage muat be lower than IC, if you write key Hashes, ori ESM will work as well which tools do you have mate? RE: MB W220 EIS &ESM VIN - Mobd3 - 12-13-2021 presently i only have xentry das star c3 as tool RE: MB W220 EIS &ESM VIN - l0x2 - 12-14-2021 Then I highly recommend you bring your vehicle to a professional, you lack the necessary tools & expertise to do what you want to do These cars are the first iteration of FBS3 they are complicated & delicate, I find later models much easier to work on RE: MB W220 EIS &ESM VIN - bersch8688 - 12-14-2021 (12-13-2021, 10:57 PM)Mobd3 Wrote: presently i only have xentry das star c3 as tool You cant do nothing with this Tools on EIS |
