Mercedes w211 problem with rear cover in trunk - Printable Version
+---- Thread: Mercedes w211 problem with rear cover in trunk (/Thread-Mercedes-w211-problem-with-rear-cover-in-trunk)
Mercedes w211 problem with rear cover in trunk - goontii - 04-11-2022
Hello Friend
I have problem with rear cover in trunk. When rear tailgate is opening then cover is moved cery well, but when tailgate closing then cover closed for max position, and cover motor not stop but working about 5 sec. Its give a strange noise from mechanism. Sensor is good.  I have only dtc about initialization from ECU. How addaptation this cover?any sugesstion?
Mercedes w211 problem with rear cover in trunk - AndyTech - 04-11-2022
There was an adaption option but was removed in latest versions. I usually set it to max manually then press and hold the button for 10-15 sec then close - open 2x time
Sent from my SM-N976B using Tapatalk
RE: Mercedes w211 problem with rear cover in trunk - goontii - 04-11-2022
But which button do you mean??
RE: Mercedes w211 problem with rear cover in trunk - AndyTech - 04-12-2022
Close button or both close and lock in some models
