Bmw f30 problem with a/c compressor engage - Printable Version
+---- Forum: BMW Group BMW, Mini Discussions. (https://mhhauto.com/Forum-BMW-Group-BMW-Mini-Discussions)
+---- Thread: Bmw f30 problem with a/c compressor engage (/Thread-Bmw-f30-problem-with-a-c-compressor-engage)
Pages: 1 2 3 4
Bmw f30 problem with a/c compressor engage - gilbert250 - 05-22-2022
Hello i have a problem with bmw f30 with a/c. Everything its ok temp. Outside temp. Inside refrigerant pressure 5bar compressor run-out protektion in ista set to 0 adding refrigerant (before less 200g)but no clutch on in compressor still off. I try test compressor in istad and everything work fine (2 minute test a/c) refrigerant grow up to 8 bar fan working and temp inside low but when i stop test a/c not working. I try test in fem clutch compressor and ok. Check FA in esysy and its original. I code full module with ori FA and the same problem. Change ihka module on air  distributor, coding and the same problem. Please help me because i dont know what is wrong. Check coding in ihka and fem and "magnet coupling" set to on. Thanks for help.
RE: Bmw f30 problem with a/c compressor engage - kartalmotors - 05-22-2022
So you filled it with wrong gas 🙈
RE: Bmw f30 problem with a/c compressor engage - gilbert250 - 05-22-2022
Before was 350g and i refill to 550g
RE: Bmw f30 problem with a/c compressor engage - geosan1638 - 05-23-2022
(05-22-2022, 08:21 PM)gilbert250 Wrote: Hello i have a problem with bmw f30 with a/c. Everything its ok temp. Outside temp. Inside refrigerant pressure 5bar compressor run-out protektion in ista set to 0 adding refrigerant (before less 200g)but no clutch on in compressor still off. I try test compressor in istad and everything work fine (2 minute test a/c) refrigerant grow up to 8 bar fan working and temp inside low but when i stop test a/c not working. I try test in fem clutch compressor and ok. Check FA in esysy and its original. I code full module with ori FA and the same problem. Change ihka module on air  distributor, coding and the same problem. Please help me because i dont know what is wrong. Check coding in ihka and fem and "magnet coupling" set to on. Thanks for help.
(05-22-2022, 09:42 PM)gilbert250 Wrote: Before was 350g and i refill to 550g
I have the exact same issue. mine was not triggering the magnetic clutch but after updating the car it started to work in ista but not when pressing the ac button. did you make any progress ?
RE: Bmw f30 problem with a/c compressor engage - gilbert250 - 05-24-2022
SO far no progress
RE: Bmw f30 problem with a/c compressor engage - sergekart - 05-24-2022
After what you have got this problem? Any retrofitting?
Client buy car with this problem. I check VO and is original. I recode all module with original vo and no results.
RE: Bmw f30 problem with a/c compressor engage - badboy2k9 - 05-24-2022
Outside temperature sensor working?
RE: Bmw f30 problem with a/c compressor engage - sergekart - 05-25-2022
I can try to see and check your car remotely.
