W211 SBC Issue - Printable Version
+---- Thread: W211 SBC Issue (/Thread-W211-SBC-Issue)
W211 SBC Issue - CarService4Oaks - 07-29-2014
Hi all and thank you in advance,
The W211 saga continues on my end. Code C235A (Service Threshold Reached) is active and stored. I have tried the erase procedure specified in the attachments that I found here on MHH (with SD Ddeveloper Kit) and it doesn't seem to help. Is there any other way to reset the life counter on the SCB control Module?
And, if there isn't, can a used good SBC unit be installed on it? Would it require full subscription to MB server for coding/flashing?
And if that is a Negative, can I install a new one without server connection to MB?
Any info is appreciated.
RE: W211 SBC Issue - webmaster - 07-29-2014
Hi mate,
You can reset the SBC using Abruties...
Regarding new SBC or 2nd hand, no need for any online flashing.
If u have for example A004.... and U installed A005.... SBC then u need to change the ESP ECU.
If the car is 2006 and above, the SBC unit will not work on W211 2003, 2004 and 2005 because U have to change ESP ECU which will not fit on the car plug.
BTW, each week I got SBC issue in my work shop.
In my opinion, it was very bad decision to install such a brake on cars!!!
Best regards.
RE: W211 SBC Issue - CarService4Oaks - 07-29-2014
(07-29-2014, 11:25 PM)webmaster Wrote: Hi mate,
Best regards.
Webmaster,
Thanks for the great info. Unfortunately, I will need extensive training regarding the usage (and what it is for that matter) of Abruties. Is there any way I can acquire this through you?
I could not agree more regarding the "Brake-by-wire" experiment that MB decided to push on all of us.
Hi mate,
If u tried the Dev mode in DAS and not work, then U need abrutis as I said.
In this case u need there Interface and software.
U have two choices:
1st: Original But very expensive ( Official site: http://www.abritus72.com/ )
2nd: Clone with reasonable price ( Look in chines sites )
Best regards.
RE: W211 SBC Issue - Rocinante - 07-30-2014
Brake by wire is a great idea, and is still used today in all Mercedes, but they went back to a brake booster instead of an electric pump booster...
I'm a firm believer in not messing with something as important as the brake system of a car.. if Mercedes says it needs a new pump, I put on a new pump or ask the customer to take the car elsewhere... but that's just me Smile
RE: W211 SBC Issue - valicat - 07-16-2015
hello, I have a w211 here with this issue as well. I don't have abrites... this morning the car had C249F and C235A DTCs. Now, after reset counters with DAS, it has only C235A... I can read eeprom with das, and I guess that with the developer functions, I can also write values (never tried)... The pump had also burned brushes, replaced and working ok... I am just missing the C235A DTC...
Does anybody know which address/value to change? I have some sbc dumps, but this one is too different to other dumps... someone who cleared this fault and has eeprom before/after... please
RE: W211 SBC Issue - ice_ghost - 12-15-2016
Hello im having the same problem , I have only C235A and i cant clear it . Have you been able to solve the problem ? If so how ?
