Need help to configure PCF7936 data iD46 transponder to work with renault car - Printable Version +- MHH AUTO (https://mhhauto.com) +-- Forum: MHH AUTO FORUMS. (https://mhhauto.com/Forum-MHH-AUTO-FORUMS) +--- Forum: Automotive Airbag, Dash, ECU, IMMO. (https://mhhauto.com/Forum-Automotive-Airbag-Dash-ECU-IMMO) +--- Thread: Need help to configure PCF7936 data iD46 transponder to work with renault car (/Thread-Need-help-to-configure-PCF7936-data-iD46-transponder-to-work-with-renault-car) |
Need help to configure PCF7936 data iD46 transponder to work with renault car - cardiag - 10-11-2011 Need help to configure PCF7936 data iD46 transponder to work with renault cars ???? Thanks RE: Need help to configure PCF7936 data iD46 transponder to work with renault car - husseinalkhalel - 01-01-2012 WHAT IS MODEL renault ? RE: Need help to configure PCF7936 data iD46 transponder to work with renault car - lupu_sandu - 01-01-2012 Use zedbull, skt-100, tango, tagkey tool, etc and precode key for Renault. RE: Need help to configure PCF7936 data iD46 transponder to work with renault car - AmPaduchi - 01-12-2012 (10-11-2011, 10:37 PM)cardiag Wrote: Need help to configure PCF7936 data iD46 transponder to work with renault cars ???? yes Yes I can help you use more types renault imobilizatoare immobox Sagem Siemens UCH, UCH Siemens primarily to renault remote key pcf7946 Pcf7936 or give treubuie precodet before being placed in the car with a diagnostic device such as EDD-Bull + OBD cable for more details http://keycontact.ro/index.php/produse/obd-systems/renault--dacia-obd.html (01-12-2012, 09:27 PM)AmPaduchi Wrote:PCF7936 precodet Renault car to be written(10-11-2011, 10:37 PM)cardiag Wrote: Need help to configure PCF7936 data iD46 transponder to work with renault cars ???? RE: Need help to configure PCF7936 data iD46 transponder to work with renault car - aleksandar28 - 01-27-2013 I have Reanult can clip , and found softvare to extract pin number , now I can code keys that have already bin coded on car but not keys from other cars . Now I am wondering can I program a virgin trasponders or this transponders need to bee prepared somehow. RE: Need help to configure PCF7936 data iD46 transponder to work with renault car - Spec - 01-28-2013 virgin transponder need to be precoded for renault, if not, car will start but you wont open it from RF key. RE: Need help to configure PCF7936 data iD46 transponder to work with renault car - buhini - 10-15-2014 (01-28-2013, 01:11 AM)Spec Wrote: virgin transponder need to be precoded for renault, if not, car will start but you wont open it from RF key. I am also interested in this topic, I have several PCF7936 pre-code, earrings but not be that codes should be put within the coding to set them in a 3 button hands free laguna/space. If I put it in the controller in password mode, this does not detect it, if I change to Crypto mode then Yes, is open almost all camera menu to be modified, but last 4 options do not, and they are including the part 6 and 7, where is introduced the encoded on the chip pcf7947. Why not is if pcf7936 chip, should put the precoded in other fields, does not is the code for pre-code. RE: Need help to configure PCF7936 data iD46 transponder to work with renault car - buhini - 10-15-2014 (01-28-2013, 01:11 AM)Spec Wrote: virgin transponder need to be precoded for renault, if not, car will start but you wont open it from RF key. I am also interested in this topic, I have several PCF7936 pre-code, earrings but not be that codes should be put within the coding to set them in a 3 button hands free laguna/space. If I put it in the controller in password mode, this does not detect it, if I change to Crypto mode then Yes, is open almost all camera menu to be modified, but last 4 options do not, and they are including the part 6 and 7, where is introduced the encoded on the chip pcf7947. Why not is if pcf7936 chip, should put the precoded in other fields, does not is the code for pre-code. |
