Where is DaVinci software? - Printable Version
+--- Thread: Where is DaVinci software? (/Thread-Where-is-DaVinci-software)
Pages: 1 2 3
Where is DaVinci software? - djholtz - 12-15-2022
Hello friends,
It was available on this forum the software DaVinci cracked.
I think it was v1.0.26 and v1.0.28!
Where is it???
RE: Where is DaVinci software? - danyboy05 - 12-15-2022
sir i dont recomand to use it is a garbage sw cracked with many problems after use the car will give black smoke behind is bad solution for egr dpf off and will delete many dtc codes which have nothing to do with dpf egr adblue so on is bad
RE: Where is DaVinci software? - djholtz - 12-15-2022
(12-15-2022, 12:30 PM)danyboy05 Wrote: sir i dont recomand to use it is a garbage sw cracked with many problems after use the car will give black smoke behind is bad solution for egr dpf off and will delete many dtc codes which have nothing to do with dpf egr adblue so on is bad
My friend I have used it with success on the works I’ve done! Now I formatted my computer and I don’t have the installation anymore, that’s why I’m looking for it!
You say it is garbage. What do you recommend to do dpf and egr off?
you used i know many people have done it but is not good i recomend winols or if you cant use winols use something better like swiftec or something else
sure is more expensive but i will never put such a files moded with davinci in customers cars you will loose sooner or later your reputation will be bad if the cars you made will go to somebody else who use proper sw you will have a bad name...is up to you is not my bussiness but i will not use it
or at least buy davinci original sw
this is just a suggestion but you do what do you want to do
RE: Where is DaVinci software? - dcb-tuning - 12-15-2022
(12-15-2022, 12:24 PM)djholtz Wrote: Hello friends,
Where is it???
buy delux its better sulutions
free update
(12-15-2022, 01:06 PM)danyboy05 Wrote: you used i know many people have done it but is not good i recomend winols or if you cant use winols use something better like swiftec or something else
I understand what you mean but winols don’t remove dpf or egr! I use winols but to do a manual solution for dpf or egr a file, I need a damos and it takes too much time!
Swiftec is very expensive and don’t work great. I prefer to keep a cracked software and run it inside a virtual machine…
Where is it???
free update
Thanks but I don’t want to buy
RE: Where is DaVinci software? - Endrino92 - 01-09-2023
(12-15-2022, 12:30 PM)danyboy05 Wrote: signore non consiglio di usarlo è un spazzatura sw rotto con molti problemi dopo l'uso l'auto darà fumo nero dietro è una cattiva soluzione per egr dpf off e cancellerà molti codici dtc che non hanno nulla a che fare con dpf egr adblue così via è cattivo
What software do you recommend me to use? thx
RE: Where is DaVinci software? - RaceEcu - 01-09-2023
You dont want to buy good oftware, but you want to earn good money with shit software.... Good job!
RE: Where is DaVinci software? - STRATOS16 - 01-09-2023
(12-15-2022, 12:24 PM)Djholtz Wrote: Bonjour les amis,
Il était disponible sur ce forum le logiciel DaVinci cracké.
Je pense que c'était v1.0.26 et v1.0.28 !
Où est-il???
Merci
hello DaVinci 1.0.26
https://mega.nz/file/5R4AgS6R
Thank you + reputation = pass
[font="MHH Font", Calibri, sans-serif]hello[/font][font="MHH Font", Calibri, sans-serif] DaVinci[/font][font="MHH Font", Calibri, sans-serif] [/font][font="MHH Font", Calibri, sans-serif]1.0.26[/font][font="MHH Font", Calibri, sans-serif] [/font]
[font="MHH Font", Calibri, sans-serif]https://mega.nz/file/5R4AgS6R[/font]
[font="MHH Font", Calibri, sans-serif]Thank you + reputation = pass[/font]
