Zenzefi Without Xentry - Printable Version
+---- Thread: Zenzefi Without Xentry (/Thread-Zenzefi-Without-Xentry)
Pages: 1 2 3 4
Zenzefi Without Xentry - bingo1309 - 06-06-2023
[Image: mk0ujOq.png]
Most of the time there are certain issues for newer cars where without Zenzefi it's not possible to use DTS or any other services on newer cars so for that this is the solution
Before downloading some questions and answers given below
1. For whom is this useful?
Ans. For people who are remote coding and without Xentry in the client PC or you're own PC where Zenzefi Dont work. have trouble in connecting to the Internet.
Terms: Installing on a Xentry System will be considered as Aftersales itself in cases when the system doesn't work this will fix the issue up to an extent. if you are installing on a NON-Xentry System the Installation will be directly considered as Supplier/Development/Production Zenzefi
2. On What application to be used?
Ans. Strictly DTS Monaco 8.14 or 16 or 9
3. Will this work for DTS Monaco 8.14 or 16?
Ans. Yes! but need modification / extra files for 8.14 or 16 so Zenzefi communication and certificates can be accessed.
4. After installing this can I code the car?
Ans. NO! you need to load the required certificates or else no point in using this.
5. What is this basically?
Ans. Zenzefi portal for the non-xentry system where just with this and DTS Monaco your jobs can be carried out.
6. What about login to zenzefi ?
Ans. No need login for this (it means if you import the certificate to zenzefi portal when using dts it will work. just import certificates from your desktop and go to dts it will work out of the box (you need to have certficates with you!)
7. Is the Zenzefi Exe Supplier/Production/Development or Aftersales
Ans. its Just Aftersales. if you install on a Xentry System, if you install on a NON Xentry system its automatically taken as Supplier/production/Development.
RE: Zenzefi Without Xentry - job - 06-07-2023
(06-06-2023, 12:40 AM)bingo1309 Wrote: [Image: mk0ujOq.png]
Ans. its Just Aftersales. if you install on a Xentry System, if you install on a NON Xentry system its automatically taken as Supplier/production/Development. if you wanted Supplier/Production/Development Just download the Zenzefi.jar given in the below link and replace it in your installed Zenzefi folder (by first stopping Zenzefi services then backup the jar and replace it, and run the Zenzefi services.cmd once in admin and one in normal.
8. Is there the latest Zenzefi Version available?
Ans. Yes there is the Latest version available (aftersales Zenzefi.jar) version 1.96.0.6
9. Anything else I should be aware of?
Ans. YES! The link is password Protected you have to thank me and rep+1 me once it's done just ask in a Private message for the password.
When installed appear 26352 error. I don't know how to solve.
Solve. Just delete the already exist 'Zenzfi' cert then install again.
RE: Zenzefi Without Xentry - bingo1309 - 06-07-2023
That is because you are installing on a proper working Xentry Zenzefi System
This computer has INSTALLED XENTRY DOS before But has been uninstalled. I don't know if it has an impact.
(06-07-2023, 02:17 PM)job Wrote: This computer has INSTALLED XENTRY DOS before But has been uninstalled. I don't know if it has an impact.
The Impact would be in Registry entries, which results in Giving error.
Suggetion: Try finding zenzefi entry in registry and delete it and reintall, if not possble then only way is to use new pc,
Recommendations: Reinstall XDOS and see the thread in that follow question number 7th,
RE: Zenzefi Without Xentry - alip74 - 06-08-2023
just info: newest is 1.121.0.0
RE: Zenzefi Without Xentry - bingo1309 - 06-08-2023
(06-08-2023, 04:26 PM)alip74 Wrote: just info: newest is 1.121.0.0
Aftersales or Supplier/Development Zenzefi.jar?
RE: Zenzefi Without Xentry - alip74 - 06-09-2023
Developer
RE: Zenzefi Without Xentry - julmari - 10-12-2023
Do you know how to export certificate from xentry zenzefi to "standalone" use? Normal tool just exports public part and it cannot import because there is no private key.
