Audi A6 2014 power stering rack module change RHD to LHD - Printable Version
+---- Thread: Audi A6 2014 power stering rack module change RHD to LHD (/Thread-Audi-A6-2014-power-stering-rack-module-change-RHD-to-LHD)
Audi A6 2014 power stering rack module change RHD to LHD - mb electronic - 03-10-2023
Hello everyone
I have an Audi A6 2014 LHD with PS module total dead, I bought for 150 euros a RHD steering module, i installed this RHD module but the car's steering wheel vibrates a lot when I turn ignition on.
pls someone help me
i pay for this job
RE: Audi A6 2014 power stering rack module change RHD to LHD - Car-tech - 03-11-2023
(03-10-2023, 09:22 PM)mb electronic Wrote: Hello everyone
pls someone help me
i pay for this job
I had this same. faulty rack.
RE: Audi A6 2014 power stering rack module change RHD to LHD - mb electronic - 03-11-2023
pls someone help me
i pay for this job
rack is ok LHD, i change just module
RE: Audi A6 2014 power stering rack module change RHD to LHD - yarowsc - 03-11-2023
this is how the steering rack behaves as you change the control module from RHD to LHD and vice versa.
only; rewrite eeprom, flash from original to donor, or try coding, parameterization, adaptation - Odis Online. there is no other possibility
RE: Audi A6 2014 power stering rack module change RHD to LHD - RaffM - 03-12-2023
This can works with RCEVO ECU as well ?
RE: Audi A6 2014 power stering rack module change RHD to LHD - mb electronic - 03-15-2023
(03-11-2023, 04:21 PM)yarowsc Wrote: this is how the steering rack behaves as you change the control module from RHD to LHD and vice versa.
thank you brother
RE: Audi A6 2014 power stering rack module change RHD to LHD - viking560 - 12-23-2023
Have done this on Audi q5 2013. Very important that flash versions in both donor and original must be same. If original module is dead, and you dont know sw version, you can see it from eeprom dump. Then reflash donor to same version sw if necessary. After that swap eeprom from original to donor.  Then reflash and write parameters. You need Odis E to do the job, or even Launch device can do it with online subsctiption to Xdiag.
RE: Audi A6 2014 power stering rack module change RHD to LHD - heshamzn - 12-23-2023
if u need to adopt it online with odis just Pm Me
Online Coding Vw, Skoda , Audi , Seat - Via Odis No Charge When Failed - I Can Immo Off /Clone All Dsg And all Also Edit Mileage for All Dsg/ Med17 - edc17- simos18 , Immo off - Clone All edc17 med17,Pcr2.1 ,radio code , component protection . Odis 23 & Odis 17 instillation and Activation
RE: Audi A6 2014 power stering rack module change RHD to LHD - sunnyakins - 07-14-2025
(12-23-2023, 04:03 AM)viking560 Wrote: Have done this on Audi q5 2013. Very important that flash versions in both donor and original must be same. If original module is dead, and you dont know sw version, you can see it from eeprom dump. Then reflash donor to same version sw if necessary. After that swap eeprom from original to donor.  Then reflash and write parameters. You need Odis E to do the job, or even Launch device can do it with online subsctiption to Xdiag.
Hi sorry to bother you but want you to pls explain more to me about this audi electric steering flashing, i bought the module but from right hand vehicle try to flash with ODIS to the same version i remove, but wont work at all, once you try to turn the  steering then it start to vibrate and the steering light turns red.
so my question is when you say to read the eEPROM what tool is use to read the eeprom thanks.
