chrysler 300c u140e abs unknown configuration witech programming? - Printable Version
+--- Thread: chrysler 300c u140e abs unknown configuration witech programming? (/Thread-chrysler-300c-u140e-abs-unknown-configuration-witech-programming)
chrysler 300c u140e abs unknown configuration witech programming? - luc.b - 09-03-2014
Hi there,
I have a chrysler 300c here with a 140e error in the abs saying that it has a unknown configuration
I have a witech clone here, but i need to flash the configuration in there. But i don't know if the clone is able to do that.
Anyone ever tried that?
Thank you
Luc. B
RE: chrysler 300c u140e abs unknown configuration witech programming? - autorepair - 09-03-2014
why buy clone it is same price ass original and you get all the functions I don't think you can you have to hook up to Chrysler sever to do that that brings big risk good luck
RE: chrysler 300c u140e abs unknown configuration witech programming? - luc.b - 09-03-2014
The original is about factor 12 more expensive.
And i've read on some sites that programming is supported, but i want to make sure before trying.
RE: chrysler 300c u140e abs unknown configuration witech programming? - luc.b - 01-12-2015
Just a little bump.
The Witech clone is perfect for diagnosing doing a relearn for transmissions etc, but it will not recode your car, as it needs to connect to the server and will give you a message that its not registered. Will not be bricked instantly, but beter not temp it.
RE: chrysler 300c u140e abs unknown configuration witech programming? - lprelectronicas - 05-30-2024
did you find solution ?
RE: chrysler 300c u140e abs unknown configuration witech programming? - Davidpetrisor - 05-30-2024
Why not use witech with J2534 it only takes 2 days to register your computer then u can use any j2534 device you want
RE: chrysler 300c u140e abs unknown configuration witech programming? - Alecub - 05-30-2024
I have used several times J2534 device for car configuration recover…it always works fine for me…you only have to register your J2534 device and as soon as they approve it, you are ready to pay and start programming / configuring…good luck
