Bosch KTS 540 - Printable Version
+--- Forum: Installation Guides, Procedures & Tutorials. (https://mhhauto.com/Forum-Installation-Guides-Procedures-Tutorials)
+--- Thread: Bosch KTS 540 (/Thread-Bosch-KTS-540--387247)
Bosch KTS 540 - eurobil - 05-09-2023
Hello friends, I have received a Bosch KTS 540, how can I use it ? with esi tronic 2013 or 2016 or newer I don't want to drive with a license
or what other options are there, I am happy to receive thoughts, ideas and facts about what I can do with it
RE: Bosch KTS 540 - ibi - 05-09-2023
(05-09-2023, 09:48 PM)eurobil Wrote: Hello friends, I have received a Bosch KTS 540, how can I use it ? with esi tronic 2013 or 2016 or newer I don't want to drive with a license
Hello colleague when you install and license Bosch-ESI(tronic) year 2013 Tad with USB cable Connect KTS 540 with leptop and on the other side connect it to 12V or with Auto -automatically you will recognize and install it(Updatedrivers for KTS 540.  Open RBsys program with the classic designation Bosch and run it will open you DDC-Number number number and go to New to give you the option of searching kts-540 will see it as a usb and do a test.  kilik ok  go to the firmeware option and run -the blue line will start on the leptop and KTS blinka red light wait for it to say finished and after that it works.
regards ibi
RE: Bosch KTS 540 - eurobil - 05-09-2023
ok thanks can i use kts 540 to more like passthru ista.vida.vag........
RE: Bosch KTS 540 - paro44 - 05-10-2023
(05-09-2023, 10:15 PM)eurobil Wrote: ok thanks can i use kts 540 to more like passthru ista.vida.vag........
It works as passthru, if you set it up in DDC.
RE: Bosch KTS 540 - eurobil - 05-11-2023
Ok what is DDC
RE: Bosch KTS 540 - paro44 - 05-11-2023
(05-11-2023, 11:07 AM)eurobil Wrote: Ok what is DDC
It's the setup software for KTS (Diagnostic Device Control), where you can manage connection type (RS232, USB, wireless) and mode (passthru or diagnosis with Esitronic). If you install Esitronic, you will find it.
RE: Bosch KTS 540 - Rico74 - 01-07-2026
DDC comes with Passthruh driver setup. WIN doesnt create an entry. Not possible to uninstall with Revo.
Only U can find it in Startmenu.
