KT200 QUESTIONS! - Printable Version +- MHH AUTO (https://mhhauto.com) +-- Forum: MHH AUTO FORUMS. (https://mhhauto.com/Forum-MHH-AUTO-FORUMS) +--- Forum: Automotive Hardware. (https://mhhauto.com/Forum-Automotive-Hardware) +--- Thread: KT200 QUESTIONS! (/Thread-KT200-QUESTIONS) Pages:
KT200 QUESTIONS! - alfons37 - 07-01-2023 Anyone test kt200 on nissan 2019 sid310 and read password? Anyone test? Support MEDC17 free clone service (most of others tool need patch the files after read out ,but ours is free Give me advice about ktflash ![]() Thanks RE: KT200 QUESTIONS! - M1HX - 07-10-2023 (07-01-2023, 02:37 PM)alfons37 Wrote: Anyone test kt200 on nissan 2019 sid310 and read password? i did password over obd read obd but i was not successful with obd write.. then i did boot no problem RE: KT200 QUESTIONS! - Lucas Brave - 07-19-2023 (07-01-2023, 02:37 PM)alfons37 Wrote: Anyone test kt200 on nissan 2019 sid310 and read password? ecuhelp kt200 sid310 read write via OBD ok, read this video: [video=youtube] https://youtu.be/HqNZAmMCLrU[/video] RE: KT200 QUESTIONS! - M1HX - 07-20-2023 (07-19-2023, 01:15 PM)Lucas Brave Wrote:Have you tried it works ?(07-01-2023, 02:37 PM)alfons37 Wrote: Anyone test kt200 on nissan 2019 sid310 and read password? RE: KT200 QUESTIONS! - Lucas Brave - 07-24-2023 (07-20-2023, 11:12 PM)M1HX Wrote:yes.(07-19-2023, 01:15 PM)Lucas Brave Wrote:Have you tried it works ?(07-01-2023, 02:37 PM)alfons37 Wrote: Anyone test kt200 on nissan 2019 sid310 and read password? RE: KT200 QUESTIONS! - webgilgamesh - 07-28-2023 (07-24-2023, 11:17 AM)Lucas Brave Wrote:sid310 dont work on obd stop lying(07-20-2023, 11:12 PM)M1HX Wrote:yes.(07-19-2023, 01:15 PM)Lucas Brave Wrote:Have you tried it works ?(07-01-2023, 02:37 PM)alfons37 Wrote: Anyone test kt200 on nissan 2019 sid310 and read password? RE: KT200 QUESTIONS! - myckee - 07-31-2023 (07-19-2023, 01:15 PM)Lucas Brave Wrote:(07-01-2023, 02:37 PM)alfons37 Wrote: Anyone test kt200 on nissan 2019 sid310 and read password? This video is garbage. The title says read and write sid310, however, in the video, they do not show any reading or writing at all. They do not even show connecting!! Pure nonsense video. RE: KT200 QUESTIONS! - Lucas Brave - 08-02-2023 (07-31-2023, 01:58 AM)myckee Wrote:(07-19-2023, 01:15 PM)Lucas Brave Wrote:(07-01-2023, 02:37 PM)alfons37 Wrote: Anyone test kt200 on nissan 2019 sid310 and read password? Better in Boot and the success rate is over 90%. If on bench read, the success rate is 30%. RE: KT200 QUESTIONS! - netmanu28 - 05-08-2026 The SID310 with KT200II works perfectly on the SID310 Master 2021, via OBD, both reading and writing without any problems. In bench mode, it's the same; first, the password is extracted, and then reading and writing are possible. Right now, I'm trying to clone one that's burned out. I've already read the original and the donor ECUs; it takes about 11 minutes, but writing has taken 20 minutes so far and is at 22%. I'll give you the results when it's finished. I'm only writing the complete read data from the original ECU to the donor ECU. |
