DDE4 Quickflash - Printable Version +- MHH AUTO (https://mhhauto.com) +-- Forum: MHH AUTO FORUMS. (https://mhhauto.com/Forum-MHH-AUTO-FORUMS) +--- Forum: Automotive Software. (https://mhhauto.com/Forum-Automotive-Software) +--- Thread: DDE4 Quickflash (/Thread-DDE4-Quickflash) |
DDE4 Quickflash - Kainemoistus - 07-08-2023 Hi. Bought the DDE4 Quickflash software from here: https://www.bimmertuningtools.com/product/dde4-quickflash/ It identifies my ecu without a problem, and even reads the tune file, but when i want to read the full file it gives me an error that it cant identify the ecu suddenly. After reading the tune i switch off the ignition for 10sec as prompted, been doing everything the way it should be done, but to no avail. Ive tried the slow init and without it. Has anyone got any pointers for me? Using white pcb k+dcan cable, inpa and coding works like it should, running on Win10. RE: DDE4 Quickflash - gbratk - 08-19-2024 (07-08-2023, 11:36 AM)Kainemoistus Wrote: Hi. Hi, I have the same problem. Have you manage to solve this problem? I need to make full read urgently to make ews delete.. Thank you |
