Renault Can Clip v214 Full install kit - Mega - Printable Version
+---- Forum: Auto Software on MEGA (https://mhhauto.com/Forum-Auto-Software-on-MEGA)
+---- Thread: Renault Can Clip v214 Full install kit - Mega (/Thread-Renault-Can-Clip-v214-Full-install-kit-Mega)
Renault Can Clip v214 Full install kit - Mega - DWT76 - 10-19-2023
Last version that works good with RTL2002 probe.
Presented 02.2022
Full installation kit with Activation
* Setup
* Reg file
* KG
* Patch for RTL2002
* Clear instructions for DIY
Link to fast Mega.nz
[Image: RCCv214.png]
RATE + THANKS  then send PM for password
PM = send personal message, the button in the form of a mail envelope is located on the top right.
No need to ask password in a thread.
RATE button is at the top middle next to my reputation, just press +1.
I will answer ASAP.
RE: Renault Can Clip v214 Full install kit - Mega - tchip - 02-21-2024
Thanks for the program, I had others, but this is the last version that works with CAN SONDE. I had to work on the activation, it was not as shown in the instructions, I did not see the device number in the activation. and it was explained that there was no where to look for it, but I found it, I also used another keygen, then everything went away. To whom it may be useful, I can explain that you need to use the Renault Clip Tool, you can find it on the Internet, and the date numbers on the computer must be separated by "slash" (/), then everything works.
RE: Renault Can Clip v214 Full install kit - Mega - samoritam - 05-13-2024
(02-21-2024, 12:42 AM)tchip Wrote: Thanks for the program, I had others, but this is the last version that works with CAN SONDE. I had to work on the activation, it was not as shown in the instructions, I did not see the device number in the activation. and it was explained that there was no where to look for it, but I found it, I also used another keygen, then everything went away. To whom it may be useful, I can explain that you need to use the Renault Clip Tool, you can find it on the Internet, and the date numbers on the computer must be separated by "slash" (/), then everything works.
Hello i have the same problem. how did you change the seperation of the date numbers on the computer?
RE: Renault Can Clip v214 Full install kit - Mega - ljscodex - 07-10-2024
Hi, is it works with win 10/11 64bits?
RE: Renault Can Clip v214 Full install kit - Mega - DWT76 - 07-10-2024
(07-10-2024, 12:42 AM)ljscodex Wrote: Hi, is it works with win 10/11 64bits?
Program - yes. RTL2002 - no.
Whats the last version for RTL2002 ? do u know ?
(07-10-2024, 05:22 PM)ljscodex Wrote: Whats the last version for RTL2002 ? do u know ?
v214 with Windows 32 bit
RE: Renault Can Clip v214 Full install kit - Mega - maddy7 - 02-27-2025
In the regional settings set the short date format to dd/MM/yy
RE: Renault Can Clip v214 Full install kit - Mega - kiki67 - 04-13-2025
[font="MHH Font", Calibri, sans-serif]Can you solve these problems - Connect the token[/font]
