Volvo S80 CEM adding new ID48 - Printable Version +- MHH AUTO (https://mhhauto.com) +-- Forum: MHH AUTO FORUMS. (https://mhhauto.com/Forum-MHH-AUTO-FORUMS) +--- Forum: Automotive Airbag, Dash, ECU, IMMO. (https://mhhauto.com/Forum-Automotive-Airbag-Dash-ECU-IMMO) +--- Thread: Volvo S80 CEM adding new ID48 (/Thread-Volvo-S80-CEM-adding-new-ID48) |
Volvo S80 CEM adding new ID48 - autorisp - 10-15-2014 I have a 1998 S80 2.5 TDI with CEM I and engine control unit 0281001776. Engine not crank and not start because key is not recognized ( Immo is active ). The key is working properly and I think it is a problem of syncro . I read the 28F400 on CEM and the 24C04 on engine control unit . I used the program VOLVO SYNCHRONIZATION UTILITY V1.4 to synchronize the CEM and the engine ECU . Now I have to add a new ID48 transponder but I do not have CARPROG . Can you help me suggest to a program or someone can add it manually ? Iread the new transponder with Zedbull clone. Trasponeder data : ID : 0BBD0B55 UM1 : A62E8765 UM2 : AAAAAAAAAAAAAAAA CHIP: MagicII Type: 48 CRYPT MEGAMOS The old original Key : ID : 20BF4500 UM1: 5D158779 CHIP : MagicI LOCKED TYPE: 48 CRYPT MEGAMOS Tanks to All, |
