ODIS-S 23.0.1 + ODIS-E 17.0.1 + KEYGENS FREE - Printable Version +- MHH AUTO (https://mhhauto.com) +-- Forum: MHH AUTO FORUMS. (https://mhhauto.com/Forum-MHH-AUTO-FORUMS) +--- Forum: Automotive Software. (https://mhhauto.com/Forum-Automotive-Software) +---- Forum: AUTO Software on Torrent (https://mhhauto.com/Forum-AUTO-Software-on-Torrent) +---- Thread: ODIS-S 23.0.1 + ODIS-E 17.0.1 + KEYGENS FREE (/Thread-ODIS-S-23-0-1-ODIS-E-17-0-1-KEYGENS-FREE) |
ODIS-S 23.0.1 + ODIS-E 17.0.1 + KEYGENS FREE - RaThek - 11-19-2023 Hello, here you will find both ODIS Service and Engineering latest versions with respective keygens. 1. Install ODIS (during instalation select license file from "Patch & License\license" directory). 2. Overwrite plugins dir and OffboardDiagLauncher file from "Patch & License" directory to installation location in "Program Files". 3. On the first run you will be asked for activation, run keygen from "Patch & License" copy HW ID from ODIS, enter name, select all sections and generate key to copy back to ODIS. Windows Defender gives false-positive warnings about keygen so you have to allow it in WD settings. 4. When you will be asked for PostSetup location select "ODIS-Service_update_23_0_1" as source (mount "PostSetup_20230619.iso" in case of ODIS-E) and wait to finish. If you have an error saying about insufficient rights close ODIS and re-run with administrative rights. 5. After all you will be asked to restart Windows and that's all. Thx & Rep are welcome. There is no password protection. RE: ODIS-S 23.0.1 + ODIS-E 17.0.1 + KEYGENS FREE - guidotacco - 11-20-2023 hi,work whit 5054a and windows 7? RE: ODIS-S 23.0.1 + ODIS-E 17.0.1 + KEYGENS FREE - RaThek - 11-21-2023 Not 100% sure but I think 5054 isn't supported. I don't know if it works with W7 but I think it should be. I have tested it only on W11 and 6154B. RE: ODIS-S 23.0.1 + ODIS-E 17.0.1 + KEYGENS FREE - vagvag - 11-21-2023 (11-20-2023, 09:36 PM)guidotacco Wrote: hi,work whit 5054a and windows 7?Not works with Vas5054a nor with Windows 7!!!!!!!!!!! We have discuss many times witch are the LAST versions that they support the Vas5054A....... These are, the OS 7.2.1 and OE 12.2.0 (with the famous patch for Vas5054a and for Windows 10).......... Last versions that worked with Windows 7 are OS 6.2.0 and OE 12.2.0 again............ Regarts...........
RE: ODIS-S 23.0.1 + ODIS-E 17.0.1 + KEYGENS FREE - fantomel - 11-23-2023 All this useless non-sense is now closed. All u need UNPROTECTED it is already in forum without the need of keygens and shits, same crap clean : https://mhhauto.com/Thread-Free-Activation-of-ODIS-S-23-0-1-and-ODIS-E-17-0-1 RE: ODIS-S 23.0.1 + ODIS-E 17.0.1 + KEYGENS FREE - hgmdiag - 02-13-2025 (11-19-2023, 09:01 PM)RaThek Wrote: THANKS A LOT SIR , BUT STILL ASKING FOR KEYGEN - LICENCE ! RE: ODIS-S 23.0.1 + ODIS-E 17.0.1 + KEYGENS FREE - gui_kamargo - 03-21-2025 (11-19-2023, 09:01 PM)RaThek Wrote: Hello, here you will find both ODIS Service and Engineering latest versions with respective keygens. Great friend, but I'm trying to install it when I get to the select update section, step 3 doesn't work, it gives an error, can you help me, I use Windows 10? RE: ODIS-S 23.0.1 + ODIS-E 17.0.1 + KEYGENS FREE - domancmg - 03-27-2025 does it work with vas 6154a 1.8.9 firmware? RE: ODIS-S 23.0.1 + ODIS-E 17.0.1 + KEYGENS FREE - Busso - 03-29-2025 (03-27-2025, 04:49 PM)domancmg Wrote: does it work with vas 6154a 1.8.9 firmware? Yes |
