w205 EIS coding DTS/Vediamo - Printable Version
+---- Thread: w205 EIS coding DTS/Vediamo (/Thread-w205-EIS-coding-DTS-Vediamo)
w205 EIS coding DTS/Vediamo - FleetDoc21 - 02-12-2024
Hello everybody!
Issue:
car came with buffer battery problem. On checking the voltage of the battery I made a mistake and pressed "equip with auxiliary driving system" and without any warning launch did coding. After that I`m getting messages of wrong coding and instrument cluster has blind spot communication fault. this car doesn`t have that option. tried to code that with xentry, but w205 is available with scn coding only. I also have DTS and Vediamo, but newer worked with them and I don`t want to start learning on this kind of model (it`s so complicated).
Maybe someone will able to code it for me, please?
Thank you
RE: w205 EIS coding DTS/Vediamo - globalcartuning - 02-12-2024
(02-12-2024, 06:31 PM)FleetDoc21 Wrote: Hello everybody!
Issue:
Thank you
check your PM
RE: w205 EIS coding DTS/Vediamo - gcs190 - 02-13-2024
Issue:
Thank you
Even if you had not made the mistake of clicking there, autel, launch and the like fail greatly in everything that is coding and updating, remember that. Your problem can be resolved offline through Monaco.
RE: w205 EIS coding DTS/Vediamo - FleetDoc21 - 02-13-2024
All fixed with help of zeko100 !
Thank you very much for your help!
Thanks to everybody who commented!
All coding done offline with C4, DTS/Vediamo and AnyDesk of course!
