W205 adblue - Printable Version +- MHH AUTO (https://mhhauto.com) +-- Forum: MHH AUTO FORUMS. (https://mhhauto.com/Forum-MHH-AUTO-FORUMS) +--- Forum: General Automotive Help & Discussions. (https://mhhauto.com/Forum-General-Automotive-Help-Discussions) +---- Forum: Daimler Group Mercedes-Benz, Smart Discussions. (https://mhhauto.com/Forum-Daimler-Group-Mercedes-Benz-Smart-Discussions) +---- Thread: W205 adblue (/Thread-W205-adblue) |
W205 adblue - xxminduxx - 02-13-2024 Hi have problem,Canot reset adblue system ,have 2 fault ,shows in picture ,changed nox pump,tank ,and second lamda ,and still Cant reset.DTC P13E400 Description The remaining driving distance is limited due to a malfunction in the AdBlue® system. _ P13F600 CURRENT And STORED The engine cannot be started because the exhaust aftertreatment system has been tampered with. RE: W205 adblue - gcs190 - 02-13-2024 As long as you have errors related to components of the NOx system you will not be able to solve it since those problems lead you to the current problem, we solve it first. Once cleaned of errors related to any component, you can restart the system, but you will not be able to from xentry RE: W205 adblue - momosam - 02-13-2024 (02-13-2024, 11:58 AM)gcs190 Wrote: As long as you have errors related to components of the NOx system you will not be able to solve it since those problems lead you to the current problem, we solve it first. Once cleaned of errors related to any component, you can restart the system, but you will not be able to from xentry you will need to reset and engine software update RE: W205 adblue - fotom - 02-13-2024 It depends on where the DTC is located. First look for "SCRCM_3" and erase errors, then take a look in engine control unit for further errors. I had some issues with AdBlue and had the "last start in nnn km" on the dash. At least I could reset the "last start" message but it came back until the AdBlue tank was changed. You can only reset the errors as long as you have not reached the mileage shown on the message. If there is 0km left you need to do more than just reset the counter. RE: W205 adblue - globalcartuning - 02-13-2024 (02-13-2024, 05:32 AM)xxminduxx Wrote: Hi have problem,Canot reset adblue system ,have 2 fault ,shows in picture ,changed nox pump,tank ,and second lamda ,and still Cant reset.DTC after change nox sensors and pump, lambda, you must make correct routines,make sure no faults on SCR unit,and the gauge sensor is working + tank fully filled DTS monaco should reset if no component faulty on SCR system |
