MERCEDES DSM FBS4 CLONE function verification.... - Printable Version
+--- Thread: MERCEDES DSM FBS4 CLONE function verification.... (/Thread-MERCEDES-DSM-FBS4-CLONE-function-verification)
MERCEDES DSM FBS4 CLONE function verification.... - gutmann - 03-15-2024
So far I have cloned 4 units, all good the car starts no drive authorization problem all actual values correct but the learning gear is unsuccessful. is there any member who completed the cloning successfully?I'm tired of the wordplay of companies
and spesialy abrites.
RE: MERCEDES DSM FBS4 CLONE function verification.... - Davidpetrisor - 03-15-2024
So abrites doesn't clone FBS4 correctly?? I was thinking about getting it soon, saw a video that they can do all FBS4 now
RE: MERCEDES DSM FBS4 CLONE function verification.... - gutmann - 03-15-2024
(03-15-2024, 08:35 PM)Davidpetrisor Wrote: So abrites doesn't clone FBS4 correctly?? I was thinking about getting it soon, saw a video that they can do all FBS4 now
in fact all programers are able to read pflash do same job exept virgin which i test again with online scn and server ascertains ecu was programed to other vin.
RE: MERCEDES DSM FBS4 CLONE function verification.... - DrBenzSerbia - 10-09-2024
(03-15-2024, 06:47 PM)gutmann Wrote: So far I have cloned 4 units, all good the car starts no drive authorization problem all actual values correct but the learning gear is unsuccessful. is there any member who completed the cloning successfully?I'm tired of the wordplay of companies
I literally have the same problem when cloning the FBS4 W212 DSM, after cloning the replacement dsm during calibration gets stuck in the D position
I also doubted the correctness of the replacement part, so I took another DSM that I know is correct and entered the data into it, after that I got another DSM with the same problem as the previous one.
 Only with the third DSM module did I succeed in cloning, it works without problem.
I'm trying to understand, I followed the same procedure every time, did you manage to find out what the problem was?
RE: MERCEDES DSM FBS4 CLONE function verification.... - Davidvieira - 09-02-2025
ello mate proble cause for tat its bad conection from pcb to pins in case
RE: MERCEDES DSM FBS4 CLONE function verification.... - EduardNN - 02-21-2026
The problem is that by transferring the eeprom to another unit, you transfer the initial calibration data of the Hall sensor from one unit to another, and they may not match....
