SDconnect Toolkit INTEGRATION TO NEW XDOS VERSIONS 03/2024 & UP - Printable Version +- MHH AUTO (https://mhhauto.com) +-- Forum: MHH AUTO FORUMS. (https://mhhauto.com/Forum-MHH-AUTO-FORUMS) +--- Forum: General Automotive Help & Discussions. (https://mhhauto.com/Forum-General-Automotive-Help-Discussions) +---- Forum: Daimler Group Mercedes-Benz, Smart Discussions. (https://mhhauto.com/Forum-Daimler-Group-Mercedes-Benz-Smart-Discussions) +---- Thread: SDconnect Toolkit INTEGRATION TO NEW XDOS VERSIONS 03/2024 & UP (/Thread-SDconnect-Toolkit-INTEGRATION-TO-NEW-XDOS-VERSIONS-03-2024-UP) |
SDconnect Toolkit INTEGRATION TO NEW XDOS VERSIONS 03/2024 & UP - mhh0010 - 03-24-2024 The setup integrates the missing SDconnect Toolkit program in new XDOS OpenShell versions from 03.2024 and upper. This is the latest SDconnect Toolkit version 2.1.16.1 Final Release! There includes a integration for wireless control by "Vediamo" and "DAS standalone" (corresponding corrections must be available for "XENTRY" and "DAS standalone"). The files "unins000.dat" and "unins000.exe" can be removed manually after successful program installation. ![]() ![]() ![]() Setup is password protected - request for this via PM after
The PW comes at my discretion for real users only! Don't forget to >> OFFLINE LOGIN COLLECTION:
XENTRY 03/2024 OFFLINE LOGIN BRAKING FIX IF PC ONLINE XDOS XENTRY 06/2024 OFFLINE LOGIN FIX WITH ON or OFF INTERNET XENTRY 09/2024 OFFLINE LOGIN FIX WITH ON or OFF INTERNET XENTRY 09/2024 OFFLINE LOGIN FIX WITHOUT USER+PW & WITH ON or OFF INTERNET XENTRY 12/2024 OFFLINE LOGIN FULL FIX WITHOUT USER+PW & WITH ON or OFF INTERNET XENTRY 03/2025 OFFLINE LOGIN FULL FIX WITHOUT USER+PW & WITH ON or OFF INTERNET+ XENTRY 06/2025 OFFLINE LOGIN FULL FIX WITHOUT USER PW & WITH ON or OFF INTERNET XENTRY 09/2025 OFFLINE LOGIN FULL FIX WITHOUT USER PW & WITH ON or OFF INTERNET XENTRY 12/2025 OFFLINE LOGIN FULL FIX PLUS WITHOUT USER PW & WITH ON or OFF INTERNET XENTRY 03/2026 OFFLINE LOGIN FULL FIX PLUS WITHOUT USER PW & WITH ON or OFF INTERNET
XENTRY 06/2026 OFFLINE LOGIN FULL FIX PLUS WITHOUT USER PW & WITH ON or OFF INTERNET XENTRY 09/2026 OFFLINE LOGIN FULL FIX PLUS WITHOUT USER PW & WITH ON or OFF INTERNET
================================================================================= DAIMLER TRUCK XENTRY 07/2024 OFFLINE LOGIN FIX WITH ON or OFF INTERNET DAIMLER TRUCK XENTRY 10/2024 OFFLINE LOGIN FIX NO USER+PW & WITH ON or OFF INTERNET DAIMLER TRUCK XENTRY 01/2025 OFFLINE LOGIN FIX NO USER+PW & WITH ON or OFF INTERNET DAIMLER TRUCK XENTRY 04/2025 OFFLINE LOGIN FIX NO USER+PW & WITH ON or OFF INTERNET DAIMLER TRUCK XENTRY 07/2025 OFFLINE LOGIN FIX NO USER+PW & WITH ON or OFF INTERNET RE: SDconnect Toolkit INTEGRATION FIX FOR NEW XDOS VERSIONS FROM 03/2024 - boonyen - 03-26-2024 Error when installing, anything i missed?
RE: SDconnect Toolkit INTEGRATION FIX FOR NEW XDOS VERSIONS FROM 03/2024 - mhh0010 - 03-26-2024 (03-26-2024, 07:27 PM)boonyen Wrote: This is not error... Before run install, should carefully read the instructions of the setup program, that appear before installing. These are even shown on the illustration pic of setup post #1. Sorry RE: SDconnect Toolkit INTEGRATION FIX FOR NEW XDOS VERSIONS FROM 03/2024 - GanPower - 03-31-2024 Thanks for the share but i installed and still can't connect my c4 to xentry, the icons are blue but xentry and das not connecting RE: SDconnect Toolkit INTEGRATION FIX FOR NEW XDOS VERSIONS FROM 03/2024 - mhh0010 - 04-05-2024 Corresponding corrections must be available for "XENTRY" and "DAS standalone"! Read post #1 carefully. RE: SDconnect Toolkit INTEGRATION FIX FOR NEW XDOS VERSIONS FROM 03/2024 - doctorcico - 04-06-2024 It doesn't work! no good solution RE: SDconnect Toolkit INTEGRATION FIX FOR NEW XDOS VERSIONS FROM 03/2024 - job - 04-06-2024 Please read carefully: POST 1 :::This is the latest SDconnect Toolkit version 2.1.16.1 Final Release! There includes a integration for wireless control by "Vediamo" and "DAS standalone" (corresponding corrections must be available for "XENTRY" and "DAS standalone"). If XDOS need use C4 need fix!! RE: SDconnect Toolkit INTEGRATION FIX FOR NEW XDOS VERSIONS FROM 03/2024 - boonyen - 04-07-2024 (04-06-2024, 08:18 AM)job Wrote: Please read carefully: What C4 fix, I don't understand? This is not C4 fix ? Where can I get it? Please advice TQ RE: SDconnect Toolkit INTEGRATION FIX FOR NEW XDOS VERSIONS FROM 03/2024 - mhh0010 - 04-12-2024 Now to explain again: 1. The SDconnect Toolkit INTEGRATION FIX was created for future XDOS systems, as this type of connection with a C3, C4 is no longer available!!! 2. The main distinction should be made here between the XDOS system and the XENTRY application program - they are not the same thing! 3. The fix is created for general XDOS system. 4. To ensure that XENTRY and DAS programs also run with the presented fix, appropriate corrections should also be made in these! 5. The SDconnect Toolkit INTEGRATION FIX works excellently, quickly establishes immediate and stable connections with the above Mux's, like via cable as well as WiFi! All tests and real works with 100% !!! |
