SVM --- ERP0237E unknown fault Q5 FY - Printable Version
+---- Thread: SVM --- ERP0237E unknown fault Q5 FY (/Thread-SVM-ERP0237E-unknown-fault-Q5-FY)
Pages: 1 2 3
SVM --- ERP0237E unknown fault Q5 FY - reniu12 - 05-12-2024
Hello, after connecting to geko and uploading the coding, this message appeared. SVM reports an unknown error ERP0237E.  Please help me what can I do with it unit number 8B unit number 8w0907541 software number 80A907541B
RE: SVM --- ERP0237E unknown fault Q5 FY - gordonasp - 05-12-2024
This probably means the configuration you use in the car is not comparable with the coding on the vw server
If a module  is changed with a module that’s not comparable in the vw system the system can not code it by svm
RE: SVM --- ERP0237E unknown fault Q5 FY - reniu12 - 05-12-2024
so what do I have to do now ,I got this data from the Audi website
RE: SVM --- ERP0237E unknown fault Q5 FY - yarowsc - 05-13-2024
module incompatible with the VIN of this vehicle. what was the factory ACC module installed (part number ??) or provide the number of the "master" radar
RE: SVM --- ERP0237E unknown fault Q5 FY - reniu12 - 05-15-2024
the main radar part is software number 80A907561B. 8W0907561
RE: SVM --- ERP0237E unknown fault Q5 FY - Michel R32 - 05-16-2024
try svm code : XCHG13A001
RE: SVM --- ERP0237E unknown fault Q5 FY - reniu12 - 05-16-2024
(05-16-2024, 04:18 PM)Michela R32 Wrote: spróbuj kodu svm: XCHG13A001
Mógłbyś jaśniej wytłumaczyć jak to zrobić, bo nie rozumiem
RE: SVM --- ERP0237E unknown fault Q5 FY - vagfranko - 05-16-2024
Special function, on the bottom you have SVM input code, type that code and go
RE: SVM --- ERP0237E unknown fault Q5 FY - reniu12 - 05-17-2024
(05-16-2024, 04:18 PM)Michela R32 Wrote: Pobierz kod svm: XCHG13A001
zrozumiałeś jak to zrobić, bo nie rozumiem
Funkcja specjalna, na dole masz kod wejściowy SVM, wpisz ten kod i gotowe
ok
