Axor not off engine !! - Printable Version +- MHH AUTO (https://mhhauto.com) +-- Forum: MHH AUTO FORUMS. (https://mhhauto.com/Forum-MHH-AUTO-FORUMS) +--- Forum: General Automotive Help & Discussions. (https://mhhauto.com/Forum-General-Automotive-Help-Discussions) +---- Forum: Daimler Group Mercedes-Benz, Smart Discussions. (https://mhhauto.com/Forum-Daimler-Group-Mercedes-Benz-Smart-Discussions) +---- Thread: Axor not off engine !! (/Thread-Axor-not-off-engine) |
Axor not off engine !! - aliguard - 12-02-2014 hi all good user to day i work on one acxor 3335 problem if on engine work after not off for the problem i replace PLD and FR not fix problem but off it by fuse Terminal 15 help me for the problem RE: Axor not off engine !! - graphix - 12-03-2014 (12-02-2014, 10:18 PM)aliguard Wrote: hi all good userHave you short circuit in ABS cable !! ![]() Removet from the truk
RE: Axor not off engine !! - aliguard - 12-03-2014 trailer abs cable need remove or abs control unit ?? RE: Axor not off engine !! - graphix - 12-03-2014 (12-03-2014, 10:02 AM)aliguard Wrote: trailer abs cable need remove or abs control unit ??trailer abs cable
RE: Axor not off engine !! - aliguard - 12-03-2014 !!! not have abs cable it is not trailer i disconnect Abs control unit change FR And change MR On das not problem >>>>!! RE: Axor not off engine !! - graphix - 12-05-2014 (12-03-2014, 08:58 PM)aliguard Wrote: !!! not have abs cable it is not trailer OK! Then check the small plug to pin 15 MR computer if you have not voltage when ignition is off. If yes have taken power with the ignition then you have short circuit between terminal 15 and 30 Search the electrical plan of WIS, and see where it comes clamp 15 on MR Good luk
RE: Axor not off engine !! - kiss - 11-15-2016 Hi aliguard " Please check the alternator wire. And generator control. RE: Axor not off engine !! - Dollsburg - 12-14-2016 Short circuitry on Alternator can cause this fault |
