Launch cable schematics - Printable Version +- MHH AUTO (https://mhhauto.com) +-- Forum: MHH AUTO FORUMS. (https://mhhauto.com/Forum-MHH-AUTO-FORUMS) +--- Forum: Automotive Hardware. (https://mhhauto.com/Forum-Automotive-Hardware) +--- Thread: Launch cable schematics (/Thread-Launch-cable-schematics) |
Launch cable schematics - victor2k - 07-20-2024 Hello, I have an Dbscar VII with 15 pin cable and I purchased some OBD1 adapters for Toyota ,MItsubishi,Nissan(but is 8+7 pins ,not 5+5+5 like my cable).Someone can help me with some wiring schematics ?Or I can use master GX3 cable with my Dbscar and OBD1 adapters? Thank you RE: Launch cable schematics - mattydr67 - 07-20-2024 A friend of mine use my Diagun OBD1 adapter cables with his Idiag, EasyDiag 2 and 3. So I bet you can use your GX3 OBD1 adapters. Only one think to keep in mind that the 38 pin Mercedes adapter is different then 38 pin IVECO adapter. Good luck RE: Launch cable schematics - victor2k - 07-20-2024 Hello, but I can't connect this adapter ,please look at 15 pin connectors are not the same. RE: Launch cable schematics - mattydr67 - 07-20-2024 Is that one an adapter cable. In one side there is that 15 pins connector 5+5+5 and the other side of this cable there is an OBD2 mother connector? Or what kind of connecter do you have in the other side of this adapter? Good luck RE: Launch cable schematics - victor2k - 07-20-2024 (07-20-2024, 03:41 PM)mattydr67 Wrote: Is that one an adapter cable. Hello, My cable is 5+5+5 on the bots sides,not 8+7 on the interface side and 5+5+5 on the other side. My ordered OBD1 adapters is 22 to 15(8+7 ) pins,my question how I can use this if my cable is 5+5+5(like vga cable,only female instead of male),like in the image attached in the previous post? I think there are 2 types of OBD1 adapters for Launch,one with 15 pins in two rows(8+7) and the second also with 15 pins but in tree rows(5+5+5),is any possibility to convert from one to other? Thank you RE: Launch cable schematics - mattydr67 - 07-20-2024 To conver it is easy if you have the pinout of the 15 pins connecter to OBD2 plug. I belive you have one of this cable separately or you have an OBD2 adapter that you can connect to that cable 15 to 15 pins conecter Then you can make a cable 15 pins (5+5+5) connecter to 15 pins (8+7) connecter My cable is OBD2 female plug to 15 pins (8+7) connecter It's easy to read the pinout. If you will be able to read the pinout from your 15 pins connecter to OBD2 plug this will be piece of cake to conver to GX3 adapters. Good luck RE: Launch cable schematics - Joao Antonio - 07-20-2024 Hí to all I have the same problem , no cables shematic for HD-Trucks OBD1 . some help ? thanks. RE: Launch cable schematics - victor2k - 10-25-2024 (07-20-2024, 09:27 PM)Joao Antonio Wrote: Hí to all Hello, I measured the cable,is compatible pin to pin or buy from Ali OBD OBDII for Launch X431 431 Main Cable DB 15 Pin 15Pin Male to Female 431 IV Test Master Cord OB2 Test Cable Best regards |
