Kadjar SRS Ecu - XC2336B-40 - Printable Version +- MHH AUTO (https://mhhauto.com) +-- Forum: MHH AUTO FORUMS. (https://mhhauto.com/Forum-MHH-AUTO-FORUMS) +--- Forum: Automotive Airbag, Dash, ECU, IMMO. (https://mhhauto.com/Forum-Automotive-Airbag-Dash-ECU-IMMO) +--- Thread: Kadjar SRS Ecu - XC2336B-40 (/Thread-Kadjar-SRS-Ecu-XC2336B-40) |
Kadjar SRS Ecu - XC2336B-40 - mk121 - 08-20-2024 Hello everyone, I am not able to read on bench srs ecu - 985100781R - Infineon XC2336B-40 I have VVDI prog but read out is different every time (read and used pinout in attachment). Crash has been reset with renolink (v1.94 clone) and now has DTC 908004 Internal ECU Fault which is essentially unsuccessful crash reset. At this moment I have also orange5 to try with but was unable to find any pinout. Any help welcome. Thank you RE: Kadjar SRS Ecu - XC2336B-40 - danielif - 08-21-2024 Read and Upload 64KB data flash file separately.. RE: Kadjar SRS Ecu - XC2336B-40 - mk121 - 08-21-2024 (08-21-2024, 01:31 AM)danielif Wrote: Read and Upload 64KB data flash file separately.. Hello, Flash1 in attachment. Thanks RE: Kadjar SRS Ecu - XC2336B-40 - mk121 - 09-20-2024 Solved, in second hand SRS module which also had crash stored was able to perform crash delete and fit to vehicle. RE: Kadjar SRS Ecu - XC2336B-40 - ANASDIAFIPROG - 03-02-2025 (09-20-2024, 10:17 PM)mk121 Wrote: Solved, in second hand SRS module which also had crash stored was able to perform crash delete and fit to vehicle. please confirm or not vvdiprog with this MCU i have same job RE: Kadjar SRS Ecu - XC2336B-40 - mk121 - 03-13-2025 I actually got myself renolink which did job in few seconds, I did not try vvdi prog on second unit but first one did not read well. |
