Reset Corsa d Dash - Printable Version
+--- Thread: Reset Corsa d Dash (/Thread-Reset-Corsa-d-Dash)
Reset Corsa d Dash - sayonarab - 12-14-2014
Good afternoon friends
Anyone know what is the method to Reset the Corsa D dash?
I put a new Dash from other car, (I know his pin code) then I put Opcom into the car and I went to ipc (instrument). I put the pin code and then I click in reset buttom, but I dont saw any canges. The dash always ask me the pin code from the donnor car. I think isn't reset.
Can someone tell me the procedure? Thanks
RE: Reset Corsa d Dash - to6ko77 - 12-14-2014
(12-14-2014, 11:39 PM)sayonarab Wrote: Good afternoon friends
DO YOU RESET DASH ON THE OLD CAR?
THIS IS SAME PROCEDURE
Replace the BCM (Corsa-D)
Before you replace the BCM make a note:
 Security Code
 V.I.N.
 Mechanical key number (MKN)
 CAN-High configuration
 CAN-LOW configuration
 CAN-Middle configuration
 Perform a complete diagnostic test and store the results
 Make sure that the V.I.N. matches the vehicle and other installed
Install the new BCM
 Perform CAN-High, Low and Middle configuration settings
 Program Immobilizer function, select BCM installation
 Program V.I.N. and mechanical key number in the new BCM
 Match all available keys to the BCM
 Perform a reset of these controllers:
o IPC
o BCM
o SDM
 Switch off ignition and wait at least 15 seconds
 Program Security Code in these controllers:
o IPC
o BCM
o SDM
 The new BCM has now been programmed to the car.
 Run another diagnostic-test. Clear remaining DTC's and check if all is working
fine.
RE: Reset Corsa d Dash - sayonarab - 12-15-2014
Firts of all thank you for reply me
I try in my car because the donnor car is crashed. I buy the dash online. Isn't posible to use this dash?
RE: Reset Corsa d Dash - Ashraf6119 - 12-15-2014
It is very simple...........
1) Before you do any thing first copy all Configuration from you old Dash like what is the High Can, Mid Can, Low Can, than copy the all the Variant Settings. Vin Number,
2) Fit your S/hand Dash and now plug in your Op-Com and go into Instrument enter the Pin Code from S/hand dash if the pin code is right the Reset Button will high light than click on Reset once you get reset Successful than switch Ignition OFF for 5 min than log in instrument again program your car Vin number and all the Variants and H/M/L Can Systems ans last enter your original car pin code and click on Program IPC it should tell you successful than switch ignition OFF for 5 min and log out your Op-Com.
3) Log in again clear all fault codes if any and try to start your car.........
RE: Reset Corsa d Dash - to6ko77 - 12-15-2014
OR JUST SWAP EPROMS 35080 FROM OLD DASH TO NEW!
RE: Reset Corsa d Dash - koyot - 12-15-2014
swap eeprom not good idea
(12-15-2014, 12:35 AM)Ashraf6119 Wrote: It is very simple...........
Thanks too much. Tomorrow I will try and I tell you. I do all the same except wait 5min with ignition on. I click in reset, put off the ignition and inmediately put on rhe ignition... the dash ask for the s/hand pin code still. Tomorrow I try.
Pd: I dont want to change the eprom because the part number is diferent.
Thanks for your Help Ashraf6119
I do your procedment now and all work correctly but I do a mistake introducing another pin code and now the instrument is programed with a number I dont know.
I´m thinking in read the dump with carprog? and....what pin calculator I need?
I saw too in op com:
Security Code Reset Counter-----4
Is posible to reset this advertisment?
