Laguna II 2002 S2000RPM - Printable Version +- MHH AUTO (https://mhhauto.com) +-- Forum: MHH AUTO FORUMS. (https://mhhauto.com/Forum-MHH-AUTO-FORUMS) +--- Forum: Automotive Airbag, Dash, ECU, IMMO. (https://mhhauto.com/Forum-Automotive-Airbag-Dash-ECU-IMMO) +--- Thread: Laguna II 2002 S2000RPM (/Thread-Laguna-II-2002-S2000RPM) |
Laguna II 2002 S2000RPM - ubistvo - 12-17-2014 Hello I need help with this ECU LAGUNA II 2002 1.8 16v Sagem S2000RPM I must to change the original ECU with replace one inside is eeprom 95080 I read from original dump and put in replace but car not start(the red doth stil light) I try with NYO4 immo off but again not work Can someone help me and make me this immo off Here is the dump from replace ECU Thanks RE: Laguna II 2002 S2000RPM - ubistvo - 12-18-2014 PROBLEM SOLVED THANKS TOPIC CLOSED |
