W204 - Retrofitted facelift tail lights - fog lamp error - Printable Version +- MHH AUTO (https://mhhauto.com) +-- Forum: MHH AUTO FORUMS. (https://mhhauto.com/Forum-MHH-AUTO-FORUMS) +--- Forum: General Automotive Help & Discussions. (https://mhhauto.com/Forum-General-Automotive-Help-Discussions) +---- Forum: Daimler Group Mercedes-Benz, Smart Discussions. (https://mhhauto.com/Forum-Daimler-Group-Mercedes-Benz-Smart-Discussions) +---- Thread: W204 - Retrofitted facelift tail lights - fog lamp error (/Thread-W204-Retrofitted-facelift-tail-lights-fog-lamp-error) |
W204 - Retrofitted facelift tail lights - fog lamp error - JDERUL - 12-19-2024 Hello! I have changed my tail lights from 2009 NFL to 2011 FL, coded them out and all works well except the fog lamp. My car is an EU version with the fog light on the left side. The taillights I've bought I believe they came from an UK model with the fog light on the right side (seen those dots light up before coding on the right side tail lamp). I have tried to switch off the fog lamp in the SAM and enable the right fog lamp, but unfortunately it still triggers the rear left fog lamp error message in the cluster. PRL_FoglmpLftEnable_b = nicht freigegeben PRL_FoglmpRgtEnable_b = freigegeben The above doesn't work, still triggers the error. 1. Is there any specific coding that can be done to still use that fog lamp on the right side on a LHD car without error message? 2. Can I disable the message in the cluster for that light in any way? I am fine with the backup brake light turning on instead of the dots, but still hate the annoying message on the cluster every time I enable the fog lights. Many thanks for your help! RE: W204 - Retrofitted facelift tail lights - fog lamp error - hckr891 - 12-20-2024 (12-19-2024, 06:46 PM)JDERUL Wrote: Hello! What year is your car and does it have samr204 or samr212 ? RE: W204 - Retrofitted facelift tail lights - fog lamp error - JDERUL - 12-24-2024 (12-20-2024, 04:20 AM)hckr891 Wrote:2008 and it has samr204. I've used DAS developer for coding the taillights. I've manged to turn off the error message in the cluster by disabling the NSL_LI. Was curious if anything else is affected by disabling that.(12-19-2024, 06:46 PM)JDERUL Wrote: Hello! RE: W204 - Retrofitted facelift tail lights - fog lamp error - hckr891 - 12-24-2024 (12-24-2024, 01:39 PM)JDERUL Wrote:If u have vediamo i will send the coding to - light parameter with retrofitted rear tail lights from 2012(12-20-2024, 04:20 AM)hckr891 Wrote:2008 and it has samr204. I've used DAS developer for coding the taillights. I've manged to turn off the error message in the cluster by disabling the NSL_LI. Was curious if anything else is affected by disabling that.(12-19-2024, 06:46 PM)JDERUL Wrote: Hello! RE: W204 - Retrofitted facelift tail lights - fog lamp error - JDERUL - 01-08-2025 (12-24-2024, 01:47 PM)hckr891 Wrote: If u have vediamo i will send the coding to - light parameter with retrofitted rear tail lights from 2012 Thanks, that would help to have a look and compare to what I already set. RE: W204 - Retrofitted facelift tail lights - fog lamp error - muckman - 11-20-2026 (12-24-2024, 01:47 PM)hckr891 Wrote:I have a 2010 and could use this light perameter. i have a samr_212 and vediamo(12-24-2024, 01:39 PM)JDERUL Wrote:If u have vediamo i will send the coding to - light parameter with retrofitted rear tail lights from 2012(12-20-2024, 04:20 AM)hckr891 Wrote:2008 and it has samr204. I've used DAS developer for coding the taillights. I've manged to turn off the error message in the cluster by disabling the NSL_LI. Was curious if anything else is affected by disabling that.(12-19-2024, 06:46 PM)JDERUL Wrote: Hello! RE: W204 - Retrofitted facelift tail lights - fog lamp error - tirex2k - 11-21-2026 Check if there is a wire in right taillight for fog. Use wis |
