ram file hpt to bin - Printable Version
+--- Thread: ram file hpt to bin (/Thread-ram-file-hpt-to-bin)
ram file hpt to bin - Camilo2415 - 01-07-2025
hi can any one conver hpt file to bin, i bricked it with hp tuners and now need to write it in bin thanks in advance.
RE: ram file hpt to bin - tonyalexanderm - 01-07-2025
(01-07-2025, 03:36 AM)Camilo2415 Wrote: hi can any one conver hpt file to bin, i bricked it with hp tuners and now need to write it in bin thanks in advance.
use CDA FOR REFLASHING, WITH MICROPOD
RE: ram file hpt to bin - ZooperDooper - 01-07-2025
There you go but you could have just downloaded the free util on here to do it anway from this link
https://mhhauto.com/Thread-Free-HPT-File-Editor-and-Converter-v2-5-No-Registration-Required
RE: ram file hpt to bin - Camilo2415 - 01-07-2025
It gives me a message incorrect data size.  Sad
My bad I did not realise you were using one of the latest Beta softwares to read & write this.
Like I said download the utility so you can convert to bin yourself and it can be into one file or into 2 seperate files and I have no way of knowing what your flashing utils wants.
Did HPTuners brick your ECU OR did the hpt file brick your ECU as in did you make the hpt file or did you get it from someone?
Never had HPTuners brick a ECU ever but then I only write what I read and modify.
Then again how did you even flash that hpt file in the first place when it gives you this error the moment you load it?????
[attachment=657695]
Anyway thanks for your help.
