[REQUEST] SMR-D files for W205 C43 AMG (2017) – DTS Monaco - Printable Version +- MHH AUTO (https://mhhauto.com) +-- Forum: MHH AUTO FORUMS. (https://mhhauto.com/Forum-MHH-AUTO-FORUMS) +--- Forum: Automotive Software. (https://mhhauto.com/Forum-Automotive-Software) +--- Thread: [REQUEST] SMR-D files for W205 C43 AMG (2017) – DTS Monaco (/Thread-REQUEST-SMR-D-files-for-W205-C43-AMG-2017-%E2%80%93-DTS-Monaco) |
[REQUEST] SMR-D files for W205 C43 AMG (2017) – DTS Monaco - Sylkain - 05-16-2025 Hi everyone, I'm looking for a clean set of SMR-D files specifically for my 2017 Mercedes-AMG C43 W205 to use with DTS Monaco 8.16. I already have DTS Monaco running with a J2534 passthru (SM2 Pro), and I’m ready to start coding — but I’m missing several key SMR-D modules. Here is the list of what I need: - ECO212.smr-d → Exhaust flap control - DriveUnit.smr-d → ESP, Start&Stop, Individual - HU5.smr-d → Infotainment (Android Auto, Individual config) - IC213.smr-d → Instrument cluster (AMG display, oil temp) - CPC_NZ.smr-d → Torque coordination - ME97.smr-d → Engine ECU (variant reading only) - SAMF205.smr-d → Front body module (lights, comfort) - PARKMAN213.smr-d → Parking sensors, camera If you have a working DTS Monaco project for W205 C43 AMG with these files (or a reliable source path for them), I would really appreciate it 🙏 Thank you in advance for your help — I’m happy to like and rep! Cheers, Thomas RE: [REQUEST] SMR-D files for W205 C43 AMG (2017) – DTS Monaco - MBMK - 08-31-2025 Hey I alsi recently started coding my c43 amg 2016. My ECU is located in MED177v6LA smr-d and not MED97. You can check by scanning the module in xentry. Start stop was also in MED177v6LA and is called Betriebstrategie_start_stop it is in default ON but i set it to LAST MODE. You do need seed calculator 3.0 with the right dll files (found on this forum) and pick the dll file which has the 0b level which corresponds with level 11. Look at the videos amazing road tv posted on YouTube for a how to unlock ecu with seed calculator. Instrument cluster is IC222 on my c43 And the front body module SAMF is BC_F222 Hope you can get it to work because a lot is possible. I also set weitere schubabschaltung aktiviert so now it burbles even below 4000 rpm in sport + mode. |
