VIIPlusLoader v08.025.13 (mega+yandex) - Printable Version
+---- Forum: Auto Software on MEGA (https://mhhauto.com/Forum-Auto-Software-on-MEGA)
+---- Thread: VIIPlusLoader v08.025.13 (mega+yandex) (/Thread-VIIPlusLoader-v08-025-13-mega-yandex)
VIIPlusLoader v08.025.13 (mega+yandex) - Fdx64 - 11-09-2025
VIIPlusLoader v08.025.13 (29/10/2025) +
               VCDS 25.3.2 Release  -  25.10 (beta)
Thanks + Reputation (Rate +1) = Password
VIIPlus Loader :  is essential software for using the VCDS diagnostic system with HEX-V2 cables. It enables and manages diagnostics for VAG group vehicles (Volkswagen, Audi, Skoda, Seat)
Main features:
&- VCDS Activation: Launches and updates the VCDS software while ensuring compatibility with the HEX-V2 cable for a complete diagnostic experience.
&- Firmware updates: Automatically updates the diagnostic cable firmware upon first connection to ensure maximum compatibility with the vehicle.
&- Advanced diagnostics: Allows access to advanced coding and adaptation options for vehicle electronic systems.
&- Multilingual support: The loader supports multiple languages for simplified international use.
VCDS :
VAG COM or VCDS (VAG COM Diagnostic System) is an ultra-fast diagnostic tool exclusively for VAG group brands (VW, Audi, Seat, Skoda, and Bentley). It can also be used as an EOBD/OBDII tester. Compared to VAS brand testers (ODIS), this interface performs essentially the same functions, except for key coding and service programming of control units.
VCDS FUNCTIONS
-Read and clear error codes from all electronic systems
-Reset a maintenance interval and manage variable maintenance intervals yourself
-Actuator testing
-Retrieving measurement values and modifying basic settings
-Dynamic adjustment of the injection timing of the rotary diesel pump
-Data recording that you can display graphically
-View the control unit information
-Common Rail Injector Coding
-DPF Regeneration
-Programming a hitch device
-Calibration of components such as throttle bodies, steering angle, xenon headlights,...
-Replacing the rear brakes on vehicles equipped with an electric parking brake
RE: VIIPlusLoader v08.025.13 (mega+yandex) - Fdx64 - 11-12-2025
add to folder
VCDS : EN-IT-ES-DE-RU-ZHS
RE: VIIPlusLoader v08.025.13 (mega+yandex) - Fdx64 - 11-22-2025
To request a password, please send it via private message
RE: VIIPlusLoader v08.025.13 (mega+yandex) - morti83 - 01-24-2026
(11-09-2025, 11:29 AM)Fdx64 Wrote: VIIPlusLoader v08.025.13 (29/10/2025) +
Main features:
VCDS :
VCDS FUNCTIONS
-Actuator testing
-DPF Regeneration
RE: VIIPlusLoader v08.025.13 (mega+yandex) - barteczekk - 01-26-2026
It is for flyvcds?
RE: VIIPlusLoader v08.025.13 (mega+yandex) - Fdx64 - 01-26-2026
(01-26-2026, 01:56 AM)barteczekk Wrote: It is for flyvcds?
For Vcds
RE: VIIPlusLoader v08.025.13 (mega+yandex) - samircz - 03-08-2026
(11-09-2025, 11:29 AM)Fdx64 Wrote: VIIPlusLoader v08.025.13 (29.10.2025) +
               VCDS 25.3.2 Verze - 25.10 (beta)
Díky thankyou
RE: VIIPlusLoader v08.025.13 (mega+yandex) - luckysd - 03-27-2026
Main features:
VCDS :
VCDS FUNCTIONS
-Actuator testing
-DPF Regeneration
[font="MHH Font", Calibri, sans-serif]Thanks for sharing it with us.[/font]
[font="MHH Font", Calibri, sans-serif] [/font]
