2010 sprinter offline programming PLEASE HELP - Printable Version
+---- Thread: 2010 sprinter offline programming PLEASE HELP (/Thread-2010-sprinter-offline-programming-PLEASE-HELP)
2010 sprinter offline programming PLEASE HELP - maliy18 - 03-02-2015
HELLO TO ALL!!!
hi i'm trying to program a new transmission module for 2010 sprinter i have das/exentry with 12/2014 and offline programming and a 7-2014 flash dvd but i only see online option for the sprinter, so my question is is there any was to get it done with out going to a dealer?
thank you in advance
RE: 2010 sprinter offline programming PLEASE HELP - sam13 - 03-07-2015
i had same problem a while back seems even if you have the offline patch it doesn't cover sprinter :/
be careful what you program offline though i had a few control units update OK but loose SCN afterwards, Bosch ecu's seem to be ok
had problem with 271 engine update & 169 a class 150 petrol both had to be taken away for SCN after update
RE: 2010 sprinter offline programming PLEASE HELP - l0x2 - 01-15-2017
'New transmission' is brand new or a used unit from another car? What's wrong with the old one? You biggest problem will be SCN
RE: 2010 sprinter offline programming PLEASE HELP - viktor - 01-15-2017
(03-02-2015, 10:36 PM)maliy18 Wrote: HELLO TO ALL!!!
In your case better do ONLINE INITIAL STARTUP(SCN). If you have old vgs from this car and it's similar, you know right software number and scn coding then do job with vediamo. But better and easiest way for such situations to have fresh XDOS for SCN.
RE: 2010 sprinter offline programming PLEASE HELP - efka - 01-16-2017
2010 sprinter is 922.6 transmission with vgs 53 module in it. Let me ask what are you trying to program there?
