T-Roc Led Module 7P5941591AD change - Printable Version
+---- Thread: T-Roc Led Module 7P5941591AD change (/Thread-T-Roc-Led-Module-7P5941591AD-change)
T-Roc Led Module 7P5941591AD change - ddAdam - 12-12-2025
Hello, I had to replace left headlight and control module in 2019 T-Roc. Control module has the same number as old left and right lamp (7P5941591AD). I think this replaced module is from another car, maybe Octavia etc. so not working high beam, leveling and indicator. Can you help me to make it works with my car? I have Odis but I'm beginner.
Thank you
RE: T-Roc Led Module 7P5941591AD change - AMPERCOM - 12-12-2025
(12-12-2025, 02:50 PM)ddAdam Wrote: Hello, I had to replace left headlight and control module in 2019 T-Roc. Control module has the same number as old left and right lamp (7P5941591AD). I think this replaced module is from another car, maybe Octavia etc. so not working high beam, leveling and indicator. Can you help me to make it works with my car? I have Odis but I'm beginner.
Thank you
wrong dataset, need svm
RE: T-Roc Led Module 7P5941591AD change - mukich - 12-12-2025
Thank you
You need a dataset file for this unit.
RE: T-Roc Led Module 7P5941591AD change - ddAdam - 12-12-2025
How can I get that file? Is this possible to copy from right (working) module?
RE: T-Roc Led Module 7P5941591AD change - yarowsc - 12-12-2025
You need VCP or Odis Online for write properly flash file
RE: T-Roc Led Module 7P5941591AD change - ddAdam - 12-16-2025
Loading proper dataset by Odis-E fixed the problem. Thank you all
