sd connect c4 chinese obd2 cable wiring diagram - Printable Version +- MHH AUTO (https://mhhauto.com) +-- Forum: MHH AUTO FORUMS. (https://mhhauto.com/Forum-MHH-AUTO-FORUMS) +--- Forum: General Automotive Help & Discussions. (https://mhhauto.com/Forum-General-Automotive-Help-Discussions) +---- Forum: Daimler Group Mercedes-Benz, Smart Discussions. (https://mhhauto.com/Forum-Daimler-Group-Mercedes-Benz-Smart-Discussions) +---- Thread: sd connect c4 chinese obd2 cable wiring diagram (/Thread-sd-connect-c4-chinese-obd2-cable-wiring-diagram) |
sd connect c4 chinese obd2 cable wiring diagram - autoteque - 03-09-2015 hello all, i am trying to find the pin out diagram for my sd connect c4 obd2 to MUX cable, i am fairly sure that i have a bad cable, i used my 2012/11 xentry, didnt connect, so i used the das stand alone and it connected to my ml500 2002 model did quick scan etc....cleared some codes.... i went and connected it on a 2001 slk32 and a sl500 2001 as well, without even taking the cables and dongle out......tried 2 different mux.... no connection on either car....came back still with cables attached tried on my ml500 again no connection......my guess is a broken wire in obd2 cable...the only diagrams i find on your site are not the same .....see attached pictures of mine.... any help greatly appreciated.[attachment=72176][attachment=72176][attachment=72176].......................................no one seems to have a wiring diagram of the obd2 cable??.....it would seem that the automatic update made my xentry lock both my mux, i am in process of trying to get unlock program from DieTRih..... RE: sd connect c4 chinese obd2 cable wiring diagram - liakontas - 03-28-2015 same request by me..i have probably the same problem so i need the wirig diagram for obd2 of sdconnect RE: sd connect c4 chinese obd2 cable wiring diagram - mbaja - 10-18-2016 (03-28-2015, 06:02 PM)liakontas Wrote: same request by me..i have probably the same problem so i need the wirig diagram for obd2 of sdconnect In order to re alive this topic I'm asking also for wiring diagram of "SD connect OBD2 16pin cable". I couldn't connect to car and ignition was not recognize - I think it is cable problem. If anyone can share pinout diagram, I would appreciate it. RE: sd connect c4 chinese obd2 cable wiring diagram - mbaja - 10-25-2016 (10-18-2016, 04:38 PM)mbaja Wrote: If anyone can share pinout diagram, I would appreciate it.Here it is.. |
