PRE-SAFE NOT AVAILABLE! - Printable Version +- MHH AUTO (https://mhhauto.com) +-- Forum: MHH AUTO FORUMS. (https://mhhauto.com/Forum-MHH-AUTO-FORUMS) +--- Forum: General Automotive Help & Discussions. (https://mhhauto.com/Forum-General-Automotive-Help-Discussions) +---- Forum: Daimler Group Mercedes-Benz, Smart Discussions. (https://mhhauto.com/Forum-Daimler-Group-Mercedes-Benz-Smart-Discussions) +---- Thread: PRE-SAFE NOT AVAILABLE! (/Thread-PRE-SAFE-NOT-AVAILABLE) |
PRE-SAFE NOT AVAILABLE! - mneligan1 - 03-10-2015 Hi all. I have a problem with 2002 Mercedes W220 S320CDI showing PRE-SAFE NOT AVAILABLE! Fault on the dash and can’t clear it, has anyone come across this fault before? Thanks in advance. RE: PRE-SAFE NOT AVAILABLE! - QBAelectric - 03-10-2015 You've got srs light on. Fix it and the pre safe message will go out. PRE-SAFE NOT AVAILABLE! - mneligan1 - 05-17-2015 Got the pre-safe sorted. Changed settings in the dashboard Sent from my iPad using Tapatalk RE: PRE-SAFE NOT AVAILABLE! - thushi91 - 05-17-2015 you play with lives becareful!
RE: PRE-SAFE NOT AVAILABLE! - erickdnt - 01-04-2017 HAVE SOLUTION DISABLE PRE SAFE? RE: PRE-SAFE NOT AVAILABLE! - Rocinante - 01-04-2017 Check the coding in the cluster to make sure it matches the car... no reversible retractable seatbelts in pre 2003 cars.. RE: PRE-SAFE NOT AVAILABLE! - erickdnt - 01-06-2017 (01-04-2017, 07:37 AM)Rocinante Wrote: Check the coding in the cluster to make sure it matches the car... no reversible retractable seatbelts in pre 2003 cars..Thx Pre safe in Ml 350 2009 have solution disable? Vediamo? i do no? i payt for service i need disable this urgente. |
