ESP 8.1i coding issue - Printable Version +- MHH AUTO (https://mhhauto.com) +-- Forum: MHH AUTO FORUMS. (https://mhhauto.com/Forum-MHH-AUTO-FORUMS) +--- Forum: General Automotive Help & Discussions. (https://mhhauto.com/Forum-General-Automotive-Help-Discussions) +---- Forum: VAG Group VW , Audi, Seat, Skoda, Bentley Discussions. (https://mhhauto.com/Forum-VAG-Group-VW-Audi-Seat-Skoda-Bentley-Discussions) +---- Thread: ESP 8.1i coding issue (/Thread-ESP-8-1i-coding-issue) |
ESP 8.1i coding issue - Dynamic12 - 03-13-2026 Hi. I've lost ABS pump coding on Fabia 2012 1.2 TSI CBZB Automatic transmission. With ESP calculator i got 410148DB417200B5822C12EB82D400400100 code but the car wont accept it. Somebody can give me the right code for this unit ? ESP8.2i VAG nr.: 6R0907379AL HW: 6R0907379AF SW: 001 VIN: TMBEN65J3C3153793 Rear brakes on disk, Whats wrong with the generated code ? RE: ESP 8.1i coding issue - rabaukee - 03-14-2026 The problem with that coding is, that it is invalid. If you are in need to write proper coding without using ODIS (online) you can make use of this service on selling box to fix with proper coding by VIN. No need for ODIS in that case, you can use any tool you like to writethe coding. |
