EDC15C0 Immo off Mercedes Vito Start error - Printable Version
+--- Thread: EDC15C0 Immo off Mercedes Vito Start error (/Thread-EDC15C0-Immo-off-Mercedes-Vito-Start-error)
EDC15C0 Immo off Mercedes Vito Start error - cengiz383838 - 04-12-2026
Hello, I'm getting a start error in the dashboard and the vehicle won't start.
I read that it's possible to disable the immobilizer without an emulator.
Who can do that? Thanks
RE: EDC15C0 Immo off Mercedes Vito Start error - danielif - 04-12-2026
What tool you used for read the file. Best file for make immo off is readed in external porgrammer unsoldering the flash. If the vehicle is equipped with EZS system, the key
must be recognized otherwise the starter relay must
be bypassed.
EDC15C0 HARDWARE: 33.98 SOFTWARE: 1037351117
Solution avalable, PM
RE: EDC15C0 Immo off Mercedes Vito Start error - cengiz383838 - 04-13-2026
NO EZs System. Ignition going on. Dashboard says start error... No Crank.
RE: EDC15C0 Immo off Mercedes Vito Start error - ninoher96 - 06-05-2026
(04-12-2026, 10:29 PM)Danielif Wrote: ¿Qué herramienta usaste para leer el archivo? El mejor archivo para desactivar el inmovilizador se lee con un programador externo desoldando la memoria flash. Si el vehículo está equipado con el sistema EZS, la llave
debe ser reconocida; de lo contrario, se debe puentear el relé de arranque
Solución disponible, PM
te he hablado por PM cuando puedas me contestas porfavor.
RE: EDC15C0 Immo off Mercedes Vito Start error - danielif - 06-05-2026
check PM..
