Stage 1 Exhaust temperature over 900 degree problem - Printable Version +- MHH AUTO (https://mhhauto.com) +-- Forum: MHH AUTO FORUMS. (https://mhhauto.com/Forum-MHH-AUTO-FORUMS) +--- Forum: Automotive Tuning. (https://mhhauto.com/Forum-Automotive-Tuning) +--- Thread: Stage 1 Exhaust temperature over 900 degree problem (/Thread-Stage-1-Exhaust-temperature-over-900-degree-problem) |
Stage 1 Exhaust temperature over 900 degree problem - marceldsl - 04-19-2026 Hello, I have the following problem: I had a Stage 1 tune with SCR deactivated on my Mercedes-Benz G350d (245 hp, 2017 model). The car drives great. However, the check engine light came on at 158 km/h. The error code is P2080FA. The exhaust temperature rose to over 900 degrees Celsius, and the car went into limp mode. Unfortunately, the diesel particulate filter (DPF) has to remain installed because, due to the Euro 6 emissions standard in Germany, a particulate test is performed during the mandatory vehicle inspection, which it would fail. Xentry shows a DPF fill level of 58% and a particle count of 3.75 grams. My question is whether the problem is due to the purchased software optimization or, as the tuner suspects, to the DPF itself, which needs to be removed. Unfortunately, I lack the expertise to assess this. Thank you for your time and help. Best regards, Marcel RE: Stage 1 Exhaust temperature over 900 degree problem - AutoManiac - 04-19-2026 (04-19-2026, 02:00 AM)marceldsl Wrote: Hello, I dont have file that is close to ur, so adding a stock file to ur post will easy the proccess for us. Anyway, tunes rises the temp, this isnt a secret, we ask from car to burn more and it has some effects. As far as i know this car, this 3 litter engine is strong, but going over 900 degree on 160 km\h is too much, cheating it or deleting this error may cause engine dmg. Doing stage with DPF on IS STUPID, but alot do and all fine so DPF is half of the problem. I sugest to you to lower fuel amount or adding some air if possible, this will lower the temp, and make logs, maybe ur temp sensor is faulty and it is showing to high temp when it isnt. Good luck! RE: Stage 1 Exhaust temperature over 900 degree problem - mb055 - 04-19-2026 stage ain`t calibrated well, however you can always log with stock file and see that is tuning related... better calibration should fix the issue and dpf can remain functional when properly made.. RE: Stage 1 Exhaust temperature over 900 degree problem - DaniXDX - 04-19-2026 Check the tune... Your problem is low lambdas (to much diesel o not enought Air) , retarded SOI, overfuelling... RE: Stage 1 Exhaust temperature over 900 degree problem - DJ_DOGGY - 04-19-2026 Only from the post, without look into file, i can assume: Yep, another incompetent remap. RE: Stage 1 Exhaust temperature over 900 degree problem - habib - 04-19-2026 There are several issues in this file. Most notably, the boost pressure setpoint (PCR_pDesBas_MAP) and the corresponding limit (PCR_pDesRawLim_CUR) have not been adjusted. RE: Stage 1 Exhaust temperature over 900 degree problem - AvS33 - 04-19-2026 Hello, I would start with a proper diagnosis. I would check the values at different temperature ranges and the temperature sensors. Perhaps the ECU is stuck in a permanent regeneration pattern. Check if the engine oil is contaminated and if the level hasn't increased. It could also be a partial SCR issue. Otherwise, flash the original file and check the values. Good luck. RE: Stage 1 Exhaust temperature over 900 degree problem - nilshn29 - 04-20-2026 (04-19-2026, 02:00 AM)marceldsl Wrote: Hello, This tune is not calibrated, just some brainless changes. RE: Stage 1 Exhaust temperature over 900 degree problem - ludbe - 04-20-2026 on mb-s need really pay attention to rail pressure and soi-s to get egts somewhat ok |
