Need Help EWS3 dump file - Printable Version
+--- Thread: Need Help EWS3 dump file (/Thread-Need-Help-EWS3-dump-file)
Need Help EWS3 dump file - evo13 - 05-13-2026
Hi everyone
I did a mistake on EWS3 on  E39 528i 1998, part number is 61.35-8 382 453, 608 377 UTA HW 02 SW 05, MCU 2D47J. Now data lost so i cant crank or start the car.
Would you please anyone has dump file, please give me to start my car again?
Thank you
RE: Need Help EWS3 dump file - sixcode - 05-13-2026
what ECU you have as probably it can be made immo off
RE: Need Help EWS3 dump file - evo13 - 05-13-2026
(05-13-2026, 11:36 AM)sixcode Wrote: what ECU you have as probably it can be made immo off
Hi Sixcode
Thank you very much for your reply. My DME is MS41.0, and i dont want to do immo off
RE: Need Help EWS3 dump file - pekibg - 05-15-2026
hi , this is EWS3 in EWS2 mode , you can just edit vin and write my dump in your ews (dont edit isn manualy),make key and install on the car, then with inpa via diagnostic port read dme isn and write in ews.
