Mercedes CLA 118 Tow Bar Problem - Printable Version +- MHH AUTO (https://mhhauto.com) +-- Forum: MHH AUTO FORUMS. (https://mhhauto.com/Forum-MHH-AUTO-FORUMS) +--- Forum: General Automotive Help & Discussions. (https://mhhauto.com/Forum-General-Automotive-Help-Discussions) +---- Forum: Daimler Group Mercedes-Benz, Smart Discussions. (https://mhhauto.com/Forum-Daimler-Group-Mercedes-Benz-Smart-Discussions) +---- Thread: Mercedes CLA 118 Tow Bar Problem (/Thread-Mercedes-CLA-118-Tow-Bar-Problem) |
Mercedes CLA 118 Tow Bar Problem - Sebi76 - 05-21-2026 I have installed a Tow Bar on my Vehicle. The problem is, that nothing happens when I actuate the switch. I then noticed that the control unit indicates the Tow Bar has not been initialized (Image Initialize). But i can´t initialize ,upon checking the actual values, I saw that the Tow Bar is listed as "unlocked"!? However, it *is* locked. I then proceeded to measure the wiring. Measuring between (Image Schematic)Sens_GND and Sen_2 (Pins 5 and 7): Pin 5 shows continuity, but Pin 7 does not. I tried grounding both pins, but the status display in the actual values did not change not even when I actuated the switch.(Image Values) When the Tow Bar is locked. Witch SEN2 Pin 5 & 7 has continuity. RE: Mercedes CLA 118 Tow Bar Problem - Anturage - 05-21-2026 Initial startup was not performed. RE: Mercedes CLA 118 Tow Bar Problem - Sebi76 - 05-21-2026 (05-21-2026, 09:39 PM)Anturage Wrote: Initial startup was not performed. Have you read my Post carefuly!? It doenst work because the restriciton Tow bar is locked is not complete RE: Mercedes CLA 118 Tow Bar Problem - Anturage - 05-21-2026 Read second time - same solution RE: Mercedes CLA 118 Tow Bar Problem - Sebi76 - 05-21-2026 (05-21-2026, 10:07 PM)Anturage Wrote: Read second time - same solution Do you see in the Picture? But i found the Failure. It is mechaniclly blocked. RE: Mercedes CLA 118 Tow Bar Problem - Sebi76 - 05-22-2026 I plug off the Motor. What does the Shaft Do? RE: Mercedes CLA 118 Tow Bar Problem - Sebi76 - 05-23-2026 So i fixt it with WD40 ![]() Another Question.: Has anyone a Backup of Coding from the Tm205 please!? RE: Mercedes CLA 118 Tow Bar Problem - AMC. - 05-24-2026 (05-23-2026, 03:22 PM)Sebi76 Wrote: So i fixt it with WD40 I have, write pm for which car do you need it RE: Mercedes CLA 118 Tow Bar Problem - Sebi76 - 05-25-2026 (05-24-2026, 03:22 PM)AMC. Wrote:That works for me. Perfect Thanks(05-23-2026, 03:22 PM)Sebi76 Wrote: So i fixt it with WD40 |
