FORD Technical Information System (TIS) Outcode/Incode - Printable Version +- MHH AUTO (https://mhhauto.com) +-- Forum: MHH AUTO FORUMS. (https://mhhauto.com/Forum-MHH-AUTO-FORUMS) +--- Forum: Automotive Airbag, Dash, ECU, IMMO. (https://mhhauto.com/Forum-Automotive-Airbag-Dash-ECU-IMMO) +--- Thread: FORD Technical Information System (TIS) Outcode/Incode (/Thread-FORD-Technical-Information-System-TIS-Outcode-Incode) |
FORD Technical Information System (TIS) Outcode/Incode - maarv726 - 05-31-2026 Hello, I want to change a BCM Module on a Ford Smax from 2008. I have a used BCM Module and need to write immo form ca in module. With autel I can generate a outcode from the module. Now I need a incode and for this I need a outcode/incode generator. Can someone help me? Greetings from germany RE: FORD Technical Information System (TIS) Outcode/Incode - Davidpetrisor - 05-31-2026 Post out code I should be able to get u in code for this model year u can dm me also if u want to remember out code changes with each ignition cycle so u have to keep ignition on till u input in code RE: FORD Technical Information System (TIS) Outcode/Incode - maarv726 - 06-04-2026 (05-31-2026, 09:32 PM)Davidpetrisor Wrote: Post out code I should be able to get u in code for this model year u can dm me also if u want to remember out code changes with each ignition cycle so u have to keep ignition on till u input in code I have sent you a PM RE: FORD Technical Information System (TIS) Outcode/Incode - pavlo1983 - 06-05-2026 Send the code and we'll see what we can do. |
