renault master 3 sid321 2023 - Printable Version
+---- Forum: Renault Group Renault, Dacia, Nissan Discussions. (https://mhhauto.com/Forum-Renault-Group-Renault-Dacia-Nissan-Discussions)
+---- Thread: renault master 3 sid321 2023 (/Thread-renault-master-3-sid321-2023)
renault master 3 sid321 2023 - alex1971 - 06-12-2026
I need help, please!
Renault Master 3, SID321 ECU: when I turn on the ignition, relays start clicking after 10 seconds. There are 3 or 4 relays involved—one is under the glovebox, and the others are in the engine bay.
There are no error codes. When I start the car, it fires up but stalls after 10 seconds, then starts again... If I give it more gas, the engine doesn't have time to stall. It seems like the ground signal to the supply relay drops out for 1 second; then the relay engages, the engine runs for 5 seconds, the relay cuts out for 1 second, and this cycle repeats continuously.  I suspect the ECU. I bought another identical flash chip for the SID321. I installed it in the car; the relays click on, and then—silence (no more clicking), but it won't start. Flex won't read the EEPROM.How do I read the EEPROM and change the VIN and IMMO data?
OR how to link a block? I don't think this is the only case. help me figure it out....
This is the original file; can anyone tell me where the immo data is located? (Willing to pay.)
RE: renault master 3 sid321 2023 - alex1971 - 06-13-2026
hi  There is no one to help.
RE: renault master 3 sid321 2023 - mike_service - 06-13-2026
Hi
First ,its not Renault ,maybe Nissan Interstar
Second,your file its not original,someone have disable a lot of switches with shavel !
Hi, I mixed up the file—sorry about that.
That’s not the point—the question is how to link the donor ECU.
The same thing happens on the original.
RE: renault master 3 sid321 2023 - alex1971 - 06-14-2026
There’s no one to help. Are there no specialists for the Renault Master 4?
