Airbag Ecu Vin Problem - Printable Version
+--- Thread: Airbag Ecu Vin Problem (/Thread-Airbag-Ecu-Vin-Problem)
Airbag Ecu Vin Problem - suki_suzuki - 06-13-2026
Hello everyone,
I have a problem with my Fiat Tipo 2021 1.0GSE, the car was flooded, and I changed everything with the help of the original MultiEcuScan diagnostics, but I can't make the airbag ECU, I would like to copy the data from the old to the new one or to change the chassis number from the new one, so I'm wondering what tool I can use to do that.
The is ecu fiat numabre:00052211320 - s/n:00896 - zf ecu
Thanks in advance.
RE: Airbag Ecu Vin Problem - namoty - 06-14-2026
Hello, you need to open the airbag unit and look at the type of processor or eeprom. There are many programmers that can read those units. It is possible that your original unit may not be readable due to water damage.
RE: Airbag Ecu Vin Problem - kirchan - 06-14-2026
(06-13-2026, 07:39 PM)suki_suzuki Wrote: Hello everyone,
Thanks in advance.
I can adjust vin. More info:
https://mhhauto.com/Thread-ABS-REPLACE-FIAT-500X-JEEP-RENEGADE?pid=2846675#pid2846675
